Tl431, MOSFET shunt voltage regulator - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th March 2014, 03:43 PM   #1
jetbat is offline jetbat  United States
Default Tl431, MOSFET shunt voltage regulator
I was wondering if the transistor in this circuit could be replaced with a P channel MOSFET like the IRF9610?
Old 13th March 2014, 03:50 PM   #2
Mooly's Avatar
Probably, as long as you remember that the FET needs around 4 volts across its G-S to turn on compared to the 0.6 of a bjt. So that places a lower limit on your regulated voltage.
Old 13th March 2014, 05:16 PM   #3
Thanks. I just wasn't sure if there was something I over looked.
If it works the regulated voltage should stay the same. The IRF9610 has a gate-source threshold voltage of -2 to -4V. *The TL431 would pull the gate voltage down till the MOSFET turns on. The reg voltage should still be set by the voltage divider at the TL431 reference input.
Old 13th March 2014, 07:24 PM   #4
Mooly's Avatar
As long as you have the voltage to play with it should be OK. No good if you only want say a regulated 3.3 volt rail or whatever.
Old 13th March 2014, 11:37 PM   #5
trobbins's Avatar
I've used that format - very simple and sharp knee.
The 431 cathode resistor can be split in series if you want the 431 cathode voltage at regulation point to be say around 2-5V if the supply input was say 12-24V. The 431 regulation current needs to be above a certain level - see datasheet.
Also, the dissipation in the FET can be mainly moved in to a power resistor in the drain, which is very practical for larger power applications where the FET junction temperature management becomes high priority - but the FET heatsinking still needs to cope with half the supply voltage dissipation condition.
Old 14th March 2014, 03:19 PM   #6
I understand.
Thanks.
Understanding shunt voltage regulator circuit jetbat Power Supplies 10 31st December 2013 05:40 PM
My take on a discrete shunt voltage regulator iko Power Supplies 1262 9th April 2013 04:04 AM
Shunt Regulator variations (Parallel voltage regulator variations) for SS Pre-Amp tiefbassuebertr Solid State 2 15th December 2012 10:09 AM
Simple opamp/mosfet shunt regulator iko Solid State 64 12th March 2009 06:38 PM
Tube for a shunt voltage regulator jarthel Power Supplies 14 26th October 2006 04:19 AM
Copyright 1999-2017 diyAudio
