Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th March 2014, 07:12 AM   #1
Default ultra low noise PSU recommendations for VAS of the LME49830
Im trying to build a psu for LME49830 and would like to know how to get ultra low noise from the psu without using any valves.
Old 6th March 2014, 07:18 AM   #2
S4m is offline S4m
I think you need to know the necessary voltage first...
It starts from +|-20V and can handle +|-100V
Old 6th March 2014, 07:34 AM   #3
I have various versions of the amplifiers to do from
+/-30v to +/-90v
to be precise..
1. +/- 33v
2. +/- 60v
3. +/- 90v
I was just checking these from TI http://www.ti.com/lit/ds/symlink/tps7a3301.pdf
that is applicable only till 33v but with micro volts noise so anything beyond that need to look at other sources any suggestions please
Old 6th March 2014, 03:07 PM   #4
use a medium voltage Salas style shunt reg, or a high voltage series regulator of the Jung/Didden style.
regards Andrew T.
Old 6th March 2014, 03:41 PM   #5
thank you andrew. Actually Im more concern about the noise floor. As the supply noise itself will be in the order of milli volts. I have seen the TI product which states about the output noise being 16micro volts. It makes the solution attractive but only worried about the higher voltage solutions. I have a doubt that does the Jung/Didden circuit has lower noise in the order of micro volts?
Old 6th March 2014, 04:01 PM   #6
this one seems to do the job till 90V what do you say..
Linear Regulator (LDO) - Single Channel LDO - TPS7A4001 - TI.com
Ultra Low Noise and Low Power Consumption OCXO ULNOCXO Vendor's Bazaar 16 12th April 2014 10:08 PM
Ultra Low Noise - Ultra Low Impedance - Ultra big Problems! Stefan0815 Analog Line Level 2 14th January 2014 06:01 AM
ultra low noise low distortion preamplifier needed neazoi Solid State 13 11th October 2011 01:03 PM
Ultra-low Noise Valve Regulated PSU. How to? Kenneth Zhu Tubes / Valves 9 5th October 2010 07:18 PM
Ultra low noise filters tiroth Solid State 14 21st May 2002 10:19 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
