Zener Follower - what did i do wrong? - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd March 2014, 07:26 AM   #21
Merlinb is offline Merlinb  United Kingdom
Merlinb's Avatar
Originally Posted by CBS240 View Post
Post 10 has the right idea. This is for a headphone amp so low noise should be a priority, in which case you should definitely scrap the noisy Zener. IMO
The OP said the zener was bypassed with a big cap. Such an arrangement is in fact extremely quiet.
Old 3rd March 2014, 07:36 AM   #22
jcx is online now jcx  United States
bypassing a Zener with a big cap is very inefficent use of parts - the Zener's low dynamic Z with adequate bias makes for a high corner frequency - much better to make a RC low pass afer the Zener
Old 5th March 2014, 01:08 AM   #23
Update: i (kind of) followed Mooly's circuit and it works.
This is my current schematic.
Mooly's schematic shows a 2nd capacitor where the question marks are. Minor question and pretty sure the answer is yes, but in case i missed something, can i put 100uF cap there? I happen to have one lying around. I don't know, shorting that TIP122 and now using a sensitive MOSFET made me paranoid about transients.
Old 5th March 2014, 06:40 AM   #24
Mooly's Avatar
Adding a 100uf will greatly improve the ripple rejection of the circuit.
Old 5th March 2014, 08:08 AM   #25
Merlinb's Avatar
You don't normally put a capacitor in that position, since it will cause you to lose all the AC regulation that a regulator is supposed to provide! I'm not sure if it is a mistake in Mooly's diagram, or if he really means to regulate only DC and not AC (ripple).
Mooly?
Old 5th March 2014, 10:30 AM   #26
Mooly's Avatar
Mooly?
It wasn't a fully worked example tbh, a workable circuit yes, but not optimised.
Here is the sim file (so you can alter and see the effect of changes). As it stands there is a pulsed load (severe test) and you can see the effect of making R6 either 15k or short and how the ripple alters. Its far less in amplitude with a cap fitted in that location. As always though, you need to balance all aspects of a design to best suit your needs.
File Type: zip Regulator.zip (910 Bytes, 5 views)
Old 5th March 2014, 10:52 AM   #27
Merlinb's Avatar
That's because the capacitor makes the circuit work as a capacitor multiplier, not a regulator! For a regulator you would normally have a capacitor in parallel with R3 (1 to 10uF say), which increases the feedback as far as AC is concerned, and tends to stabilise the regulator.
Old 5th March 2014, 11:41 AM   #28
Mooly's Avatar
That's why I said you need to balance all the design aspects
Do you want max ripple rejection or best performance against transient load fluctuations. There is no one size fits all.
If the load is dynamic (and a headphone amp whether class a or class b) should in practice have minimal changes in supply current) then you need to look at what the min and max variation might be and over what time period.
I posted the sim file so that it can be tweaked by the user to suit the requirements.
Hot follower/cool follower webercarbmann Solid State 13 2nd November 2010 02:23 PM
Zener + Emitter Follower voltage regulator Alcaid Solid State 90 1st June 2010 11:12 PM
Wrong Voltage / current on BoZ... or Wrong Measuring ? gionag Pass Labs 8 14th May 2008 11:24 AM
Question about direct coupling a anode follower into a cathode follower. G Tubes / Valves 45 29th July 2004 06:47 PM
Copyright 1999-2017 diyAudio
