Power supply caps: They're not all equal - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 27th February 2014, 07:42 AM   #11
Originally Posted by infinia View Post
IMO ripple ratings is a throw away number pretty much
Cant be verified easily > generated by # crunchers at the factory / it's kinda like MTBF of a HDD LOL
What is the exact definition of a "ripple rating"? It seems like a vaguely defined parameter. I like measurements, equations, and graphs.
Old 27th February 2014, 09:22 AM   #12
the specified maximum continuous AC current passing through the capacitor that allows the capacitor to meet all it's other specifications.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 27th February 2014, 09:23 AM   #13
If you can run the capacitor at 10% of it's ripple rating, then it will achieve it's other specifications for a lot longer.
regards Andrew T.
Old 27th February 2014, 11:40 AM   #14
DF96 is offline DF96  England
It is a vaguely defined parameter, yet a very important one. See post 12 for as good a definition as you are likely to get.
Old 27th February 2014, 12:24 PM   #15
infinia is offline infinia  United States
infinia's Avatar
If it's vague, how could it be important for a design engineer> LOL
probably weight/ mass is a better indication of durability IMO
like four million tons of hydrogen exploding on the sun
like the whisper of the termites building castles in the dust
Old 27th February 2014, 03:03 PM   #16
Thank you.
Sounds like a good idea.
Old 27th February 2014, 03:30 PM   #17
Destroyer OS's Avatar
The life hours are under load cycle at high temp. Used in the average amplifier they could decades on 24/7, possibly. They usually last a lot of years.
Are they equal? No...
Old 27th February 2014, 04:01 PM   #18
Probably because they are run at far cooler than the rated maximum temperature.
The internal heat generating mechanism is the ESR times the ripple current.
The external heat source is the Ta.
There is a further short term heat source. Leakage current times ESR.
Reduce the ripple current and reduce the Ta and the capacitors will generally last 10 times to 1000 times the lifetime quoted in the specification.
regards Andrew T.
Old 27th February 2014, 04:19 PM   #19
infinia's Avatar
trusted vendors + higher temp rating 105*C + lower esr = better long lasting capacitors full stop ,
the ripple current is just a numbers game.
the Big Ones usually last much longer than the little ones.
next up how to buy Automotive Batteries LOL
Old 27th February 2014, 06:22 PM   #20
Rundmaus's Avatar
If you really believe that, you may place a nice 105C, low esr cap of sufficient voltage, and a beefy diode across a beefy transformer secondary while you sit on that cap for a few minutes = all specs met except ripple current, that's just a numbers game.
I'd like to see your lower back region after that experiment.
Rundmaus
Power supply Caps a.wayne Solid State 3 27th August 2009 02:26 PM
Power supply options.. bigger trafo with less caps or medium trafo with heavy caps? rhythmdiy Chip Amps 9 23rd October 2007 12:30 AM
Power supply caps leander Solid State 8 14th October 2005 05:33 AM
same amps, different supply voltages. Equal volume? Hybrid fourdoor Chip Amps 1 12th July 2004 11:32 PM
Copyright 1999-2017 diyAudio
