How to deal with Litz wire - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd February 2014, 06:26 PM   #1
nigelwright7557's Avatar
Default How to deal with Litz wire
I am working on a switch mode power supply.
I have found that using four strands for a conductor works well.
However I was told that Litz wire is the best way to go.
How do I work with say 100 strands ?
How do I remove the insulation for soldering ?
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk http://www.pcbcad51.co.uk
Old 23rd February 2014, 06:45 PM   #2
diyAudio Moderator Emeritus
jean-paul's Avatar
If you adjust this one not too tight it will work OK. Otherwise precutting with a Stanley knife works too. One circular cut and one vertical one should be enough. Test a few times on a piece of that specific cable and try to cut just deep enough so without touching the copper. You can pry the cable's insulation open by the vertical cut and when you reach the circular cut you'll see that it can be removed easily.
It's only audio. Member of the non modular PCB design committee
Old 23rd February 2014, 06:48 PM   #3
kevinkr's Avatar
Make sure you buy a heat strippable litz wire. I use various litz wires in my projects, the stuff with cotton or nylon thread jacket is easily tinned, the stuff in teflon jacket you must first strip and then tin. Tinning can be done easily with a solder pot or with a reasonably hot solder iron with a little patience.
"To argue with a person who has renounced the use of reason is like administering medicine to the dead." - Thomas Paine
Old 23rd February 2014, 06:49 PM   #4
ishiru is offline ishiru  Indonesia
ishiru's Avatar
isn't you just need to let your soldered soldering tips touching the litz for let's say a few seconds until the insulation melted?
i ever repaired a sennheiser headphone cables (they're litz) and that's what i did..scratching that tiny cables just make them falling apart
iono wat i do
Old 23rd February 2014, 07:02 PM   #5
Bob Richards's Avatar
At Tektronix they had little "pots" of moulton solder that we would dip the litz wire into. It would burn off all the cloth insulation and solder all the individual wires together perfectly. Now (retired) I just melt a big glob of solder onto the last 1/4 inch and hold the solder iron under it for several seconds until I think the insulation is mostly burnt off, but the solder itself isn't yet damaged from too much heat, and there it is.
Old 23rd February 2014, 08:19 PM   #6
kevinkr's Avatar
Bob, this is pretty much how I do it too, not really enough room for a solder pot in my tight work space.
Old 23rd February 2014, 08:27 PM   #7
jean-paul's Avatar
The described technique worked with cotton insulation but I would not do that with plastic insulations... Either toxic gasses in the lungs or other stuff happening that will corrode your copper.
Old 24th February 2014, 12:23 PM   #8
luka is offline luka  Slovenia
luka's Avatar
Send a message via Skype™ to luka
if the insulation is ok, you just solder it and that burns off the insulation in the area, that kinda litz wire is very easy to work with... not like standard wire, where is very hard to burn of insulation... and its better to strip it off before
home page @ http://www.classdaudio.tk/ @ 24/7 all year long
I FEEL SLOVENIA
Old 24th February 2014, 12:59 PM   #9
Bigun is offline Bigun  Canada
Bigun's Avatar
I've used Litz wire to make radio coils. You have to buy the right kind - the kind that you can burn off the insulation with a soldering iron. I bought mine on eBay - there are different grades - the more wires the finer each wire is and the more expensive it is.
First you unwind the cloth covering, usually two layers have to be unwound and they are wound in opposite directions. The covering is a very fine material so you remove it carefuly. Then heat the end of the wire bundle with a soldering iron tim with fresh solder, the flux helps with the process. Leave the iron on there for awhile until you've really burned it off good.
The wire kinks very easily so be careful when handling it.
"The test of the machine is the satisfaction it gives you. There isn't any other test. If the machine produces tranquility it's right. If it disturbs you it's wrong until either the machine or your mind is changed." Robert M Pirsig.
Old 24th February 2014, 07:19 PM   #10
The cloth insulation is designed to be burnt off, otherwise how would you ever use it. I haven't heard of the plastic insulation. That sounds like some new cheaper way to do it. The fumes probably are worse with plastic. I'd avoid that kind.
Litz Wire for audio applications (18AWG, New England Wire Type 2) Chook81 Vendor's Bazaar 2 24th January 2012 08:32 PM
litz inductor wire for speaker wire. fazman Everything Else 126 20th June 2011 02:48 PM
Litz Wire Selection microsim444 Power Supplies 5 2nd December 2009 10:19 PM
LITZ wire gearheaddruid Swap Meet 0 11th January 2005 05:07 AM
Litz Wire - Where to buy? ClassD Parts 0 5th April 2004 06:37 AM
Copyright 1999-2017 diyAudio
