parallel transformers - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th February 2014, 11:51 AM   #1
Default parallel transformers
i have two identical transformers, both with two (same) seconderies.
what will be the preferred way to connect them to a diode bridge? in exact paralle way or every transformer will give one phase?
please take a look on the attached figure.
TX
Roi
Old 10th February 2014, 12:33 PM   #2
jcx is offline jcx  United States
why not dual mono?
Old 10th February 2014, 01:37 PM   #3
DF96 is offline DF96  England
If the two transformers really are absolutely identical then either will do.
If they are slightly different then the upper circuit may create circulating currents or force one to do all the work. The lower circuit will work fine but may give more ripple or slightly unbalanced + and - rails.
I would use the lower circuit.
Old 10th February 2014, 01:59 PM   #4
Elvee is offline Elvee  Belgium
Elvee's Avatar
This scheme will ensure the balance, even if the transformers are slightly different:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 10th February 2014, 06:21 PM   #5
That puts them in series, but I think the OP wants parallel.
Parallel Output Transformers gingertube Tubes / Valves 6 24th August 2010 11:46 PM
Parallel Output Transformers gerryc Tubes / Valves 20 26th September 2007 06:03 AM
Parallel transformers and bridge Raka Power Supplies 16 14th July 2005 07:15 AM
parallel transformers Aunkst Parts 15 29th October 2004 01:16 PM
parallel the transformers billy Pass Labs 36 5th June 2004 02:57 AM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
