RC chains capacitor swap - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th February 2014, 03:45 PM   #1
emosms is offline emosms  Bulgaria
Default RC chains capacitor swap
A very lame question:
This is part of ps for a tube project.
What if a swap the capacitors c1 and c2 - 22uf first, 100uf second.
I guess there would not be any difference in ripple smoothing.
Reason - a smaller 100uF cap/400V for a smaller ps unit.
Anyway the voltage will be less than 400v
Unfortunatelly, I am going to use the resistor only to drop the voltage to the value needed for the tubes, not really calculating the rc chains.
Voltage taken on the second cap.
Old 6th February 2014, 04:41 PM   #2
DF96 is offline DF96  England
Both caps need to be able to take the full voltage.
Putting the small cap first will reduce charging pulses and make good grounding slightly less important. It will increase voltage droop under load. Ripple at the output will be largely unchanged.
Old 6th February 2014, 05:36 PM   #3
Thx,
What do you mean "make good grounding slightly less important"?
Some more details pls, about how it affects grounding, e.t.c... Where can I do some readings about it?
No load voltage is going to be app. 360, maybe more. (going to test a custom made transf. these days)
I wanted to put 22(47)uF/450v first and 100uF/400v second.
.. But, the supply will be detachable, so with no load there would be almost no drop at C2.
or at least I think so.
p.s.
Got this software, but cant really use it yet
PSUD2
Old 6th February 2014, 05:55 PM   #4
There is plenty about grounding both here and elsewhere on the net.
If the charging pulses are slightly smoother, due to a smaller reservoir cap, then they will create slightly smaller problems due to ground currents or magnetic induction.
Old 6th February 2014, 06:08 PM   #5
I prefer the small cap before the big cap.
This is because the big cap supplies virtually all the near instantaneous current that the load demands.
But the first cap of a rCRC string takes a lot of punishment. It must have an adequate ripple capacity.
4k7 and 100uF is an enormous RC time constant.
That makes me ask: is the 4k7 also doing a double duty? Is it dropping the high B+ voltage to a lower voltage to suit another circuit?
regards Andrew T.
Old 6th February 2014, 06:33 PM   #6
I am following a 'verbal rule' that a drop of f.ex. 30 volts is good to achieve ripple smoothing.
100uf - the bigger the better 'verbal rule' .
Ok, I will do some more reading about valve ps, but the primary purpose of 4k7, or whatever it comes, is to set my V1 voltage to 300v under load.
Then there will be anotherRC chains going parallel, to supply other valves:
Considering heater elevation as well - I am going to test a topology with a tube cathode follower.
Testing anyway with a heater elevation for hum reduction (non tube CF version)
Calculated the reservoir capacitor according to
http://www.valvewizard.co.uk/smoothing.html
It comes about 15uF. Suplying preamp with a current draw of 5mA
Old 7th February 2014, 10:27 AM   #7
Be aware that a highish LF/subsonic supply impedance (4.7k) may help create the conditions for motorboating.
Old 7th February 2014, 02:42 PM   #8
Is that a matter of concern, as the PS will supply only a preamp of 2 tubes?:
One common cause is feedback through the plate power supply circuit.[2][4] The power supply provides DC current to each tube's plate circuit, so the power supply wiring (power busses) can be an inadvertent feedback path between stages. The increasing impedance of the filter capacitors at low frequencies can mean that low frequency swings in the current drawn by output stages can cause voltage swings in the power supply voltage which feed back to earlier stages,[2][4] making the system a subaudio oscillator. This is caused by inadequate power supply filtering or decoupling.
Otherwise I think get it (more or less )
Low frequency oscillations like motorboating indicate that some device or circuit with a large time constant is involved, such as the interstage coupling capacitors or transformers, or the filter capacitors and supply transformer winding.
Do I still have large time constant, if I keep 100uF as the 'reservoir' cap, or better just to lower the value (22uF + 47uF or 47uF + 47uF)
p.s.
got my custom transf. to test . Much better than coupling а bunch of small transformers
http://s10.postimg.org/xv293p8xl/P1010240.jpg
http://s9.postimg.org/4rsln57tb/P1010239.jpg
Old 7th February 2014, 02:49 PM   #9
does swapping the 22uF and 100uF affect this instability?
Does one order (of big/small) differ from the other order (small/big) as far as instability is concerned?
Would splitting the 4k7 into an RCRC of 2k2 100uF 2k2 22uF change the stability?
At the moment he shows rCRC
regards Andrew T.
Old 7th February 2014, 04:04 PM   #10
Great option
Splitting 4k7 (whatever), 1 extra resistor before C1 to set the voltage and tweak it all.
100uF as C2.
Maybe adding a third RC chain for the V1 plate (top right corner).
//V1 is going to be a penthode.
Lowering all the secondary RC caps to 10uF/400v (out of space into the device's box..)
Components up to C2 (plus the heating stuff) are in the PSU box
No calcs and full understanding, space/design considerations before the math .
RC or CR ? kevinr Full Range 2 9th December 2013 03:26 PM
Craftsmen RC-2 SS64 Tubes / Valves 8 9th December 2011 01:09 AM
Canton ERGO RC-1 (frequency room compensation) for RC-L - Schematic wanted tiefbassuebertr Multi-Way 2 20th September 2010 11:20 AM
RE: RC-19 or RC-30 chungtat Tubes / Valves 6 6th August 2005 03:51 AM
Capacitor rated voltage: can I swap? peterpan Multi-Way 2 15th September 2003 03:45 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
