CheapoModo: quick and dirty transformer snubber bellringer jig
Old 15th March 2014, 02:36 PM   #31
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
mcandmar, I recommend you connect a fixed inductor whose inductance is known within 10%, to Cheapomodo. Then calculate the ideally perfect Rs value which gives zeta=1.000 (at this L and this Cx) using the equation in Appendix A. Set your potentiometer to this Rs value. Look at the CheapoModo waveform on your scope; at the ideal perfect zeta=1.000, your scope trace is not a flat line. The goal is not to achieve a flat line, the goal is to achieve zeta=1.000. The ideal perfect scope waveform for zeta=1.000 is shown in post #143 of the Quasimodo thread, and in several Figures of the design note.
Old 14th September 2014, 07:39 PM   #32
dimkasta is offline dimkasta  Greece
dimkasta's Avatar
Mark any news on the osh park pcb ? Are they safe for ordering?
Thanks a lot for a very nice idea and implementation
Too many projects... so little time...
Old 14th September 2014, 08:16 PM   #33
I built it and found that I hated it. The board functioned correctly, and I successfully used it to find zeta=1 snubbers for a few transformers. Despite this I hated it.
Why did I hate it: because it has too few external I/O pins. In particular, it doesn't have pins for the transformer secondary AND for the oscilloscope probe & groundclip. To use the board you have to wire up a little shiite-rig of crocodile clip jumpers, which connect the board to the transformer AND to the scope probe. Bleah.
So I tweaked the board design and made a rev.2. It worked and I didn't hate it. There were plenty of I/Os for the transformer and for the scope probe. Maybe I'll upload the PCB fab "Gerber" files in a few weeks, if I can eventually find them. Stuff is kinda jumbled up around here.
If anyone on DIYaudio wants to lay out a CheapoModo PCB, and share it with others (or sell it), please go right ahead. You have my blessings and good wishes.
Old 14th September 2014, 11:05 PM   #34
dimkasta's Avatar
Fair enough.
Do you guys mind having a look at my schematic to verify that I have not done any booboo?
CheapoModo: quick and dirty transformer snubber bellringer jig-sch-png
And here is the board
CheapoModo: quick and dirty transformer snubber bellringer jig-brd-png
It's 51x16mm and cost is going to be 6 dollars for 3 pieces from OSH park, including shipment...
How is that for a cheapo?
CheapoModo: quick and dirty transformer snubber bellringer jig-osh-png
Any comments more than welcome. I plan to order the samples at the end of the week.
Old 15th September 2014, 12:57 PM   #35
dimkasta's Avatar
I forgot to add pins for the second channel of the scope. I will add them later today
Old 15th September 2014, 03:52 PM   #36
dimkasta's Avatar
Here we go
Pins for two channel scopes, holes to attach clips to grab the secondaries, fixed width 10nF and 150nF caps (it is a cheapo anyway), mosfet drains marked with D to help orient the device of your choice and a 3pin socket for a trimmer.
Oh and it is a tiny bit smaller, so it now costs 5,85 for three pieces
Have I forgotten anything?
Old 15th September 2014, 06:38 PM   #37
Will you include a GND flood on both blue and maroon layers? The naked via next to CS1 suggests that you will. It would be a good idea.
I don't see any electrolytic bypass caps; check your deltaV = (deltaT * I / C) calculations to be sure the supply ripple will be okay when operating from a 9V battery with its relatively high internal resistance.
If you're going to discard the 2N7000 junkbox MOSFET anyway, why not replace it with a low-RDSon TO-92 MOSFET ? The one in the attachment has the same pinout as your BS170, but 15X lower Rds. You could build one of your 3 boards with good FETs and the other 2 boards with cheap FETs and see if there's a difference. {On high current 6.3VAC heater windings/transformers, there may indeed be}
Old 15th September 2014, 07:03 PM   #38
dimkasta's Avatar
Yes ground planes on both sides.
I used the BS170 because I saw it as an alternative on a previous post and I found it in the eagle libraries. I m keeping a note for the Zetex It is available on mouser for about a euro.
About the electrolytic bypass, I got a rush as soon as I saw that function
Any rough guestimates on what should be used? Something like low esr 100uF?
Old 21st September 2014, 09:01 AM   #39
Oliphant is offline Oliphant  New Zealand
Default One more successful Cheapomodo
Similar to the previous poster, I also used BC556/546, some BS170 mosfets and a prototype board to produce a cheapomodo.
It works like a charm, thanks a bunch Mark.
Old 21st September 2014, 06:18 PM   #40
Congratulations Oliphant! Nice power supply (homebrew?) in photo 3.
I assume the unconnected transformer wire in photo 3 is an electrostatic shield, rather than a primary winding connection?
CheapoModo: quick and dirty transformer snubber bellringer jigHide this!Advertise here!
Simple, no-math transformer snubber using Quasimodo test-jig Mark Johnson Power Supplies 1340 20th March 2018 09:25 PM
ECL86 - quick and dirty beamnet Tubes / Valves 44 1st April 2012 06:54 AM
Quick 'n dirty sub simulation? head_unit Subwoofers 2 29th January 2012 11:34 PM
Quick and Dirty X-over bjackson Solid State 1 16th August 2005 06:32 AM
OTL, quick `n dirty Fuling Tubes / Valves 4 27th December 2004 07:44 AM
