Maida regulator ADJ bypass
Old 19th January 2014, 09:58 AM   #1
kacernator is offline kacernator  Czech Republic
Default Maida regulator ADJ bypass
Can I bypass R6 with capacitor, say 10uF, to ground as in LM317 datasheet? Or I can not, because of maida regulator implementation?
Old 19th January 2014, 10:14 AM   #2
On Hiatus
SY's Avatar
C2 essentially does that already. You might increase its size a bit. Same with the output capacitor.
"You tell me whar a man gits his corn pone, en I'll tell you what his 'pinions is."
Old 19th January 2014, 10:19 AM   #3
Can I raise C2 from 1uF to 10uF to gain more ripple rejection and lower noise?
Old 19th January 2014, 10:26 AM   #4
On Hiatus
SY's Avatar
Yes. It will slow down the transient response of the regulator, which worries some, but I would argue that this is a good thing. It reduces the amplitude of change at the regulator output with current changes and shifts the Fourier components of the output response to much lower frequencies. In my own circuits, I tend to make C1 much bigger, 47u or so.
Maida regulator ADJ bypassHide this!Advertise here!
Maida regulator Andrewc556 Tubes / Valves 21 31st December 2010 04:29 AM
LR8N3 Regulator -- Bypass the ADJ pin jackinnj Power Supplies 1 10th December 2007 06:26 PM
Maida regulator billr Tubes / Valves 15 23rd September 2007 04:19 PM
Maida's regulator mark_titano Tubes / Valves 3 29th January 2006 03:26 PM
Bypass your adjustable regulators ADJ pin to ground to hear another veil drop... Dr.H Digital Source 1 1st August 2002 05:48 PM
Copyright ©1999-2017 diyAudio
