Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th December 2013, 01:27 PM   #1
hansibull's Avatar
Default Rectifier caps; go for the huge ones?
Hi!
I'm finishing up my power supply circuit, and my rectifier PCB looks like this:
I got 6x 10000uF and 6x 22000 uF, but I don't know what's best suited for driving a 2.1 amplifier. is it true that bigger is better?
Old 25th December 2013, 06:01 PM   #2
DUG is offline DUG  Canada
With larger caps there is less ripple but higher peak current spikes through the transformer and rectifiers.
Initial turn-on can also be an issue with some fast blow fuses and stiff transformers.
IMO ESR is more important.
Check the specs.
And choose wisely
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 25th December 2013, 11:40 PM   #3
Mr Evil is offline Mr Evil  United Kingdom
More is definitely better, but you get diminishing returns.
Regarding peak current, it is worth reading the relevant section in the ESP power supply article (and indeed the whole article).
https://mrevil.asvachin.eu/
Old 26th December 2013, 04:18 AM   #4
Very interesting read.
I have great respect for ESP and my thoughts on diode peak current was not a result of tests but of "thought experiment".
I will have to now set something up and actually do a test to see how significant the peak diode currents are...I will have to back my opinion with results.
Thank you for politely pointing that out to me.
Rectifier options for stereo Daniels LM3875 with huge center tap transformer altie Chip Amps 4 25th May 2010 11:03 AM
HUGE LOT of caps coils resistors on ebay Mattyo5 Swap Meet 12 24th November 2008 12:58 PM
FS: 100vdc Caps--Huge Caps gengis Swap Meet 4 18th May 2005 08:20 PM
FS 6 packs of HUGE caps! glhs377 Swap Meet 1 17th January 2005 04:33 PM
Are huge DC blocking caps on Zen ok? Arx Pass Labs 13 3rd November 2003 07:38 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright 1999-2014 diyAudio
