Voltage drop in LM337 based PS!
Old 5th December 2013, 07:13 AM   #1
Roushon is offline Roushon  India
Default Voltage drop in LM337 based PS!
Built a power supply based on LM317/LM337 using
fixed resistors. Giving +- 11.3v. But when I connect the PS to the circuit (OPAMP AD8620) the + supply remain 11.3v but the - supply (LM337) drops by 1 v, that is, it shows about -10.3v. What could be the reason? Is it a standard fact about LM337? I have couple of these PS circuits built to check and LM337 shows the same phenomena!
The resistor from output to control pin is 120Ohm in both LM317 and LM337.
Thanks for any comment/reply.
Roushon.
S. Roushon
Old 5th December 2013, 08:20 AM   #2
John8 is offline John8  United Kingdom
What is the input voltage to the LM337 with the output loaded?
There should be at least 3V drop across the IC to maintain regulation. Also input and output capacitors are a good idea mounted close to the IC to avoid instability as per the data sheet.
Old 5th December 2013, 08:36 AM   #3
Mooly's Avatar
Does the negative regulator have a minimum current (check the data sheet) that must be drawn at all times ?
Old 5th December 2013, 09:22 AM   #4
payloadde is offline payloadde  Europe
payloadde's Avatar
LM317/LM337 need 10mA to go through the regualator - otherwise they may fall out of regulation
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 5th December 2013, 10:50 AM   #5
Thanks for all the comments. The input voltage is +-20v, so there is enough difference in voltage. Will check about the minimum current requirement and reduce the output-to-control pin resistor value (and hence the resistor from control to ground also).
Roushon.
S. Roushon
Old 5th December 2013, 04:51 PM   #6
martin clark is offline martin clark  Europe
Just add 1Kohm across the output from each reg to 0v to ensure that the minimum load requirement is met under all conditions.
Old 6th December 2013, 04:09 AM   #7
Great! Thanks a lot. Will do that.
Roushon.
S. Roushon
Old 6th December 2013, 04:11 AM   #8
abraxalito is offline abraxalito  United Kingdom
abraxalito's Avatar
Location: Hangzhou - Marco Polo's 'most beautiful city'. 700yrs is a long time though...
Send a message via Yahoo to abraxalito
In my experience getting the 'wrong' output voltage has been related to oscillation. Do you have a scope to check for that? The minimum current requirement would in my estimation result in a more negative output voltage being registered, not less - without enough current the magnitude of the output rises.
'The total potential here must be nothing less than astronomical.'
'Nothing less. The number 10 raised almost literally to the power of infinity.'
Old 6th December 2013, 04:25 AM   #9
mirlo is offline mirlo  United States
Question minimum load
Doesn't the 120 Ohm resistor between Output and Adjust pins take care of the min load? A little more from a 1k to ground won't hurt but I doubt this is the problem with the circuit here.
Old 6th December 2013, 01:21 PM   #10
Unfortunately, I do not have a scope. I am a bit confused now. I tried the PS with different circuits (one is a bass boost and the other is a dc- servo, both based on AD8620) which have different layouts and PCB designs. Not sure if both the circuits are oscillating. The final amp output is silent and clean. Will do some more experiments and post the result here.
Roushon.
S. Roushon
Voltage drop in LM337 based PS!Hide this!Advertise here!
What Exactly Is Voltage Drop Eddiegnz1 The Lounge 9 27th November 2013 06:24 PM
How can I drop B+ Voltage AlanJ Tubes / Valves 18 27th November 2013 02:06 AM
Regulated PS w/ LM317 & LM337's oldfatbubba Chip Amps 36 21st October 2013 04:44 PM
Voltage Drop Based On The Load OMNIFEX Solid State 29 9th May 2009 02:14 PM
voltage drop ThSpeakerDude88 Chip Amps 30 19th July 2005 10:00 PM
Copyright ©1999-2017 diyAudio
