Beefing up old PSU filter caps - advice needed! - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th November 2013, 12:54 PM   #1
bmoraru is offline bmoraru  Romania
Default Beefing up old PSU filter caps - advice needed!
On some old equipment I really like -a Dual RC 5900 receiver-- and which I'm intending to revamp, I would like to improve the PSU filter caps (6800uF), but Im wary of removing them, since they appear to be thoroughly glued on to the PCB. So I am considering of adding some new, high-performance low ESR caps in parallel with them and underneath the PCB, hence of a limited physical size.
Would adding some 1000uF worth of high quality caps make a difference? Would it make the circuit more efficient for filtering? I assume it would lower the ESR, right?
Any other thoughts? Thanks a lot!!!
Old 8th November 2013, 12:56 PM   #2
KatieandDad's Avatar
Old electrolytics are the most common failure mechanism in old electronics. Get them out and replace them. Even if they are glued to the PCB - do everything to be careful to the PCB and take them out.
Old 8th November 2013, 01:22 PM   #3
Default Update
ALthough I'm pretty skilled, removing some glued-on caps in equipment that is dear to me is the last option--for now, I am hoping for some improvement by adding some more caps in parallel...
Old 8th November 2013, 01:27 PM   #4
hates ground loops
Rodeodave's Avatar
Too much capacitance can kill diodes and/or secondary transformer windings due to exceedingly high inrush current, keep that in mind.
Gravity - Making the G since 13.7 billion B.C.
Old 8th November 2013, 01:36 PM   #5
As Rodeodave states, the inrush current of large caps has to be considered. You could probably parallel them with up to about 4700uF before you might have problems. But I would Dremel out the old ones first.
Old 8th November 2013, 02:09 PM   #6
I've never seen a glued in cap that wouldn't succumb to a square ended X-Acto knife blade worked under the glue. You really need to get those out of there because the leads are sealed in a pocket and they can eventually corrode away if the cap leaks a bit.
I may be barking up the wrong tree, but at least I'm barking!
Old 8th November 2013, 02:53 PM   #7
Max Martin's Avatar
I've done this many times. Please don't keep the old ones... They will for sure cause problems. Use a sharp knife to cut through the glue around the cap. Desolder the old ones using a "sucker" and braid to clean it properly. Use good solder like wbt 0820..
My suggestion is; Elna for audio (ebay) 8200uf and voltage no less then the old ones.
Old 8th November 2013, 05:32 PM   #8
ticktock's Avatar
Not a good idea. Don't be a fool. Follow the advice and get them out
before they do harm.
Dave, stay real. Adding 1000 F to the existing 6.800 F ones certainly
won't kill any diodes.
I'd pull them out and put some decent new 10.000 F in. Work done.
thanks
Blaue Leuchtdioden machen bld. (hb)
sent from NSA monitored device
Please . . . advice on filter caps ByronInPortland Power Supplies 21 10th August 2011 01:22 PM
PSU issues, advice needed. athos56 Tubes / Valves 6 4th January 2010 01:27 AM
Which filter caps for a PSU? fastasulike Power Supplies 3 12th December 2009 10:44 PM
FS: PSU Filter PCB's with Pass Reg + Caps Zero Cool Swap Meet 4 21st June 2005 02:44 AM
Need advice beefing up my Froys (wmtmw?) MarkB1 Multi-Way 16 10th March 2005 05:20 AM
Copyright 1999-2017 diyAudio
