Regulated PSU for Single supply Amplifier
Old 6th November 2013, 02:22 PM   #1
maouna is offline maouna  Greece
Default Regulated PSU for Single supply Amplifier
Hello.i want to build an adjustable regulated PSU for a single supply amplifier.input voltage from the transformer will be about 48V AC ,and after rectification about 66V DC.R12-R13 form a 10K trimmer. 1n5407 rectifier diodes are just for illustration.i will use a 10A bridge rectifier.
A simple schematic found in the forum made by APEXAUDIO is the one below.does it also acts like a capacitance multiplier due to the 100uF cap at base of Q11?are there any small tweaks i can apply?
Old 6th November 2013, 06:14 PM   #2
this is the schematic
Old 6th November 2013, 07:20 PM   #3
Mark Johnson is offline Mark Johnson  United States
Mark Johnson's Avatar
I personally would connect a new resistor "R33" from the collector of Q11 to the emitter of Q9. Its purpose is to establish a bias current of approximately 5 milliamperes, flowing in reference diode D8.
I personally would connect a new resistor "R43" from the base of Q10 to the emitter of Q10. Its purpose is to establish a bias current of approximately 0.8 milliamperes, flowing from collector to emitter of Q11.
Finally, I would consider inserting a fuse in series with the transformer secondary, and possibly an EMI-suppressing CRC snubber in parallel with the secondary.
Old 7th November 2013, 12:00 PM   #4
Rolf Zetterberg is offline Rolf Zetterberg  Sweden
Agree.
A simple short circuit protection can also be added in the form of three diodes from Q11 base to Vout.Should give about 3A max current.Otherwise I see no use for R15.
Further small refinements are possible.
Old 8th November 2013, 11:10 AM   #5
Forgot this:
It's advantageous to connect R33 to Vout instead of Vin,since hum and ripple is lower and the voltage is more stable.
Regulated PSU for Single supply AmplifierHide this!Advertise here!
Single Supply Class AB amplifier and PSU. Regulated,capacitance multiplier,or both?? maouna Solid State 2 4th October 2013 08:45 AM
series regulated power supply with feedback for Nelson Amplifier muddasirwaheedmalik Power Supplies 14 21st June 2012 10:27 PM
Beginners attempt at a Bench Supply or Class A Regulated PSU based on LM317 aspringv Power Supplies 12 24th July 2011 09:18 AM
PSU with regulated Supply for front-end MiiB Power Supplies 42 3rd April 2011 02:47 PM
Regulated power supply for audo amplifier SUZTEK Solid State 0 10th January 2011 07:58 AM
