10a Voltage Regulator Circuit - Resistor Question
Old 4th November 2013, 06:03 PM   #1
kballgame is offline kballgame  United States
Default 10a Voltage Regulator Circuit - Resistor Question
Hello and thanks in advance for your help. I am fairly new to circuits, so please bear with me.
I am building this circuit (subst. the lm318 for the obsolete lm107)
Questions:
1) while .1 Ohm resistors exist, they seem rare (not available at Jameco or Mouser); do they really mean 0.1 ohm resistors for R1 and R2? Which leads me to...
2) what, exactly, is the purpose of these resistors in this circuit. Can I change the value and, if so, what would you suggest?
Old 4th November 2013, 06:07 PM   #2
Mooly's Avatar
0.1 ohm is actually a common value Many amplifiers use those as emitter resistors in outputs stages.
What do they do... well it looks like they allow the opamp to respond to differences in current between the two regs and thus be able to alter the drive to one to allow perfect current sharing.
The resistors have to be low value to minimise power losses. 10amps would drop 1 volt across 0.1 ohms.
Old 4th November 2013, 06:29 PM   #3
Mooly - thank you, that makes sense.
If I were to use the .1 resistors at full draw that means they are dissipating 10 watts together and, therefore, need a 5W rating p/each. I am calculating this right, correct?
I have found a .1 Ohm 5 watt resistor at Parts Express but I find it strange they aren't carried at major suppliers like Mouser and Jameco? Perhaps I am just looking incorrectly...
Old 4th November 2013, 07:11 PM   #4
tauro0221 is offline tauro0221  United States
Yes, Mouser have it. Check it out 71-LVR05R1000FE12. 0.1 ohm 5 watts
Old 4th November 2013, 07:19 PM   #5
Mooly's Avatar
5 amps in each. Power dissipated is I squared *R so that's 25*0.1 which is 2.5 watts. So even a 3 watt resistor should be OK if used correctly but a 5 is a safer bet.
Old 4th November 2013, 08:40 PM   #6
Thanks Tauro and Mooly.
Old 5th November 2013, 07:41 AM   #7
Elvee is offline Elvee  Belgium
Elvee's Avatar
The 318 will probably not work: you need an amplifier that includes Vcc in its common mode range, like a rail to rail opamp for example, or a TLO81 that also does, but unofficially (it works though)
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 5th November 2013, 07:56 AM   #8
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
You obviously didn't search with the correct criteria.
0.1 resistor Resistors | Mouser
Old 5th November 2013, 12:03 PM   #9
Arty is offline Arty
or You can paralell some resistors to achieve 0.1 ohms.
neat thing to do in situations where dissipation would be high.
as the current would split between them.
Old 5th November 2013, 12:31 PM   #10
DUG is offline DUG  Canada
I would connect the op-amp +power (pin 7) to Vin.
Not required with the TL081 but I just would.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
10a Voltage Regulator Circuit - Resistor QuestionHide this!Advertise here!
Power rating for short circuit protection in linear voltage regulator Fusion916 Solid State 5 16th November 2012 10:20 PM
Need Negative High Voltage Regulator Circuit EBSDallas Power Supplies 13 6th January 2011 02:05 AM
Novice Voltage Regulator Question slor Tubes / Valves 39 19th January 2008 07:12 PM
high quality 10A dual voltage regulator sunrise Solid State 32 1st December 2006 12:57 PM
