Help with PS design
Help with PS design
Old 29th October 2013, 02:02 PM   #1
whitelabrat is offline whitelabrat  United States
whitelabrat's Avatar
Default Help with PS design
I just picked up a Sure Electronics TAS5630 board to cobble together an inexpensive instrument amp. I've got a giant power transformer from a failed Sansui AU-D7 that puts out about +/- 57v with a low load/idle. The schematic suggests the transformer is 41v-0-41v.
This amp will likely take a beating, so I'm looking to have a PS that can handle about 50v 12A. Unfortunately I can't do a simple CRC design where the board idles at about 100mA which is probably way less than the AU-D7, and I can't exceed 52v.
So I likely need a voltage regulator of some sort. I've searched. I've googled, but I've not had success finding anything that can handle 50v 12A. Any suggestions? It doesn't need to be quiet or super accurate.
I suppose I can just scrub off some power with some big resistors, but that's not very nice.
Old 29th October 2013, 02:37 PM   #2
Mark Johnson is online now Mark Johnson  United States
Mark Johnson's Avatar
Help with PS design
How about something simple that isn't quite a "regulator"? What if you just build an enormously beefy, oversized emitter follower or source follower, put a fixed reference voltage on its base/gate, and accepted the voltage on its emitter/source as "good enough"? There's no feedback control system; you don't sample the output, compare to a reference, and use the difference ("error voltage") to adjust the regulator.
Here's the outline of the idea; details such as fusing, Emitter-Base reverse bias protection, start-up inrush current limiting, load disconnects, and protection when the other rail fuse blows, are omitted. But perhaps they are crucial.
Old 29th October 2013, 02:44 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
A simple and effective solution is to use a small transformer connected as an autotransformer in front of your transformer: for example, a 120V to 12V transformer will shave off a little more than 10% of the voltage and only needs to have 10% of the VA rating of the main transformer
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 29th October 2013, 03:03 PM   #4
@elvee: Not sure I understand. So put the primaries of the autotransformer in line with one of the primaries of the main transformer?
I could reconfigure the iron for 220v on the primary side. That would about halve the output on the secondaries, but I may have trouble getting anywhere close to 50v.
Old 29th October 2013, 03:15 PM   #5
Help with PS design
If you do want a feedback control system including a potentiometer that lets you fine-tune the output voltage, perhaps a few parallel Nchannel MOSFETs and an NFB loop would be a possibility. I've shown 2 parallel devices but since they are so inexpensive ($1.56 qty 1 @ DK), you might prefer to build yourself an enormous SOA by connecting 4 or 6 of them in parallel.
Again, many crucial real-world details are omitted from this conceptual sketch.
Old 30th October 2013, 08:02 AM   #6
Elvee's Avatar
No, here is what I mean. You keep the input of your main transformer configured for 120V, but you subtract the voltage from the auxiliary transformer.
The drop will be more than 12V, because the regulation of the aux transformer will work backwards
Old 30th October 2013, 10:06 AM   #7
Johno is offline Johno  Australia
Johno's Avatar
Help with PS design
How beautifully clever and simple - first time I have seen that solution.
Old 30th October 2013, 01:41 PM   #8
domyboy is offline domyboy  Scotland
Have a look at the PSU im building http://www.diyaudio.com/forums/power...ml#post3682060.
i ve made a few changed since my last upload but will upload the final version tonight.
Cheers
Dom
Old 31st October 2013, 09:07 PM   #9
Thanks everyone for your posts. I have a mountain of transformers so that's a real option.
I haven't gotten any big ps capacitors yet, so I'm going to use what I've got for now in a CRCRC config for initial testing. I think big 2 ohm resistors for the R if I can find them. And then a bunch of parallel 47uF 63v LOL for the first C, and then massive 600uF 500v film capacitors for the other two C's. Just for testing.
Old 3rd November 2013, 12:23 AM   #10
So I found a 120v to 15v transformer that is about 45 VA. After wiring it up my first observation after getting the 15v phase backwards was a bit of a voltage boost. After reversing it I got a nice solid 51.9V DC with a 56k ohm bleeder resistor in place.
nice!
Help with PS designHide this!Advertise here!
amp PS design and performance? jol50 Car Audio 2 8th December 2007 11:46 PM
SB3 Shunt regulated PS design nycavsr2000 Digital Source 2 18th October 2007 04:29 AM
Help me design pre-amp PS hardcore Tubes / Valves 7 10th November 2004 06:32 AM
CD-Pro ps design gilid Digital Source 1 19th August 2004 02:14 AM
About this PS Design and Ground Scheme aborza Solid State 4 2nd December 2002 01:29 AM
