SG3524 SMPS help needed. - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th October 2013, 11:06 AM   #1
lazzer408's Avatar
Default SG3524 SMPS help needed.
I'm building a high voltage push-pull SMPS (300-400v) and need help understanding the current limiting of the SG3524
I was going to shunt the mosfets source's to ground and measure the drop across that "resistor" (12~10ga solid wire).
Please take a look at this datasheet as it's the one I'm using. http://www.ti.com/lit/ds/symlink/sg3524.pdf
In the datasheet on page 9 figure 7 it shows pin 4 to ground and pin 5 as input. On page 13 figure 15 it shows pin 5 to ground and pin 4 as input.
I'm guessing the page 11 drawing of "foldback limiting" is measuring a flyback current? which is reversed? This is where I'm confused.
Old 24th October 2013, 11:38 AM   #2
lazzer408's Avatar
Here's what I have so far.
Old 25th October 2013, 07:59 PM   #3
payloadde's Avatar
fig.7 seems to be a buck regulator case, current is measured when transistors are off, current continues to flow thru inductor, load, Rs, diode back into inductor ... thus "ground" side of Rs is actually more positive than other side, hence Lim+ at "ground".
in fig 12 emitter current of switcher transistors is measured when transistors are on, current flows thru RS to ground, so ground side is more negative than other side, hence Lim- at ground.
think you got it right ...
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 31st October 2013, 11:17 AM   #4
lazzer408's Avatar
So many questions...
I need a ~150w power supply to output a regulated ~350vdc with a current limit of around ~430ma. Above 430ma the voltage could/should sag as a means of protection. I'm still deciding on what IC to use.
1: Current mode? Voltage mode? Can someone explain the difference? 3524, 3535, 3825, 494, ect?
2: Will a pair of IRFz44 handle 150w?
3: Is the totem pole needed with a single pair of mosfets?
4: Am I on the right path with the above schematic?
5: Should I be measuring the secondary current instead?
6: Would you like to learn to fly?
7: Would you like to see me try?
I'm sure it's been said a million times but once the design is final, I'd like to order some extra boards or even make kits to sell.
Old 4th November 2013, 09:23 AM   #5
lazzer408's Avatar
I'm still looking for help.
I drew this up for the 3525 but without current limiting and remote turn-on was added. I eliminated the gate drivers because I think the 3525 can handle 2 mosfets. I still have to work out some of the values.
I started a pcb layout and had a friend cut one in vinyl for etching mask. It worked very well.
Old 4th November 2013, 10:20 AM   #6
lazzer408's Avatar
Here's my pcb layout so far. I've been trying to get it as small as I can. I forgot to add input filters though. I may have to just use an inline filter choke. Regulation goal is around ~350vdc.
Layout doesn't match the schematic 100%. I left a few pads for snubbers.
Old 8th November 2013, 04:57 AM   #7
lazzer408's Avatar
I built the circuit above and it works... without a load. 12vdc in gets me adjustable 200-380vdc out but as soon as I put a load on it (two 40w laps in series) the output drops off, input current climbs to 8A, and the mosfets get hot. The switching frequency may not be high enough?
Transformer is a 10t CT primary and a 160t CT secondary with four 1n4006 diodes for the rectifiers (all I had on hand). I'm pretty sure this core is an ETD34 but the bobbin didn't line up with my PCB which was drawn using a ETD34 pinout. I saved this core from an old PC power supply. I'll measure it in a moment to see if the core is the same as the ETD34.
Is there any tricks to getting transformers apart without breaking them? I broke 6 trying to get a good one.
Old 8th November 2013, 05:26 AM   #8
andrewlebon's Avatar
Put the core in boiling hot water for 30 mins
"It's Better to try and fail than to never know and always wonder"
Old 8th November 2013, 05:36 AM   #9
lazzer408's Avatar
Really? Does that soften of the glue? I'll be back in about 30min.
Old 8th November 2013, 05:50 AM   #10
Yes it works
Car amp smps needed kissendi Car Audio 5 28th January 2008 05:08 AM
Synchronizing SG3524. Help! darw82 Power Supplies 0 27th May 2006 07:06 PM
Synchronizing SG3524 darw82 Power Supplies 8 30th December 2005 11:58 PM
1KW SMPS help needed gearheadgene Power Supplies 93 27th September 2005 01:12 PM
Copyright 1999-2017 diyAudio
