SG3524 SMPS help needed. - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 8th November 2013, 06:12 AM   #11
lazzer408's Avatar
Out of those 5 I managed to save one. Guess it's not worth the trouble so I put in a Mouser order for 3 transformers worth.
Now I have to figure out what's wrong with this thing.
Old 8th November 2013, 06:29 AM   #12
Originally Posted by lazzer408 View Post
I built the circuit above and it works... without a load. 12vdc in gets me adjustable 200-380vdc out but as soon as I put a load on it (two 40w laps in series) the output drops off, input current climbs to 8A, and the mosfets get hot. The switching frequency may not be high enough?
Transformer is a 10t CT primary and a 160t CT secondary with four 1n4006 diodes for the rectifiers (all I had on hand). I'm pretty sure this core is an ETD34 but the bobbin didn't line up with my PCB which was drawn using a ETD34 pinout. I saved this core from an old PC power supply. I'll measure it in a moment to see if the core is the same as the ETD34.
Is there any tricks to getting transformers apart without breaking them? I broke 6 trying to get a good one.
are you sure 1N4006 are fast enough to manage your high switching frequency.
By the way I would use an octocoupler (4N35) on feedback for pwm just to isolate 12V power supply GND from audio GND.
IMHO, opltos and zener series could be the way to follow.
Old 8th November 2013, 06:56 AM   #13
palstanturhin's Avatar
Does not necessarily sound too bad...
Getting the 40W bulbs to glow might/will require more current than your supply can provide.
12*8 is only 96W, and that might be the maximum of your supply as it is configured now.
Change your output rectifier diodes. You are loosing output power in them.
Your core could be an ER-core, not an ETD... That does not matter as sush, but are you sure it does not have an air gap in it?
Computer power supplies "usually" are flyback topology. Using flyback core in a center tapped push-pull topology is not that good of an idea...
Old 8th November 2013, 08:04 AM   #14
lazzer408's Avatar
What would be the reasoning for isolation? It's not line powered.
The two 120v 40w bulbs are in series. If I adjust the voltage to 240v it should only draw 40w.
I held the cores together up to the light and didn't see any light shining through and the bobbin also floats on the core when holding the assembly together so it's not bottoming out on the bobbin either. I'm pretty sure it's not gapped. I am holding the halfs together with tape for now incase I have to change a winding. It does audibly sizzle when the PWM backs off but that's probably because the core is not very secure. Is that normal?
You are probably right about the diodes. They got really hot with not so much as a dim glow on the bulbs. Can you recommend a diode close in size to the 1n4006 that has higher speed? When I looked through Mouser I could only find larger TO220 diodes. My guess is I only need a 1A diode. 4 should do 100w output right?
Also, my secondary capacitors are only 10uf on each rail. I have more on the way but 10uf should be ok for testing shouldn't it?
Thanks for the input.
Old 8th November 2013, 10:11 AM   #15
lazzer408's Avatar
So it dawned on me to just remove the diodes and connect the bulbs right to the secondary windings. Now they light up bright. I'm seeing about 10A draw on the input. I'm not sure my meter can read AC at such a high frequency but it shows 200v. The heatsink gets slightly warm. I'm seeing ringing on the primary winding and also on the gate drive so I'll have to track that down. I have one .001uf 22ohm snubber across the primary but I'm not sure it's working because the resistor is cold. I may have to increase the capacitor value.
My layout would be easy to change to accept TO220 package diodes but I've had the trouble in the past of finding fast high-voltage dual diodes in a TO220 package.
Would these diodes work? http://pdf1.alldatasheet.com/datashe...N/FMU-22S.html
Or these? http://www.mouser.com/ds/2/149/FFPF60SA60DS-244013.pdf
I can wire them in any fashion that's required.
Old 9th November 2013, 03:58 AM   #16
lazzer408's Avatar
Tried 1n5399 diodes. Same issue.
Here's my waveform off the primary with no load. Snubbers don't do anything for the ringing. It's on the gates as well. Ideas?
Old 9th November 2013, 07:02 AM   #17
Your primary waveform is perfect...
You need ultrafast diodes,
recovery time in the nano second -range...
Old 9th November 2013, 07:28 AM   #18
lazzer408's Avatar
The ringing isn't an issue? Couldn't it cause RF interference? Anyway to dampen it or is it typically acceptable the way it is?
Old 12th November 2013, 02:50 AM   #19
lazzer408's Avatar
I've installed the new diodes and it works now but I have another problem.
I connected three 25w bulbs in series for a 75w load. I've adjusted the voltage output to 350v. At 10-12v input everything works great. The mosfets stay cool with minimal heatsinking. If I turn the input voltage up to 15v, the mosfets start to get hot quickly. Voltage still stable at 350v +/-1v.
Ideas?
Old 12th November 2013, 04:32 AM   #20
lazzer408's Avatar
Seems to be heating when the supply cuts back the PWM to regulate the output. At 12v input the PWM is closer to 50% but at 15v is backs off the PWM to maintain 350v out and that's when the mosfets get hot.
Car amp smps needed kissendi Car Audio 5 28th January 2008 04:08 AM
Synchronizing SG3524. Help! darw82 Power Supplies 0 27th May 2006 06:06 PM
Synchronizing SG3524 darw82 Power Supplies 8 30th December 2005 10:58 PM
1KW SMPS help needed gearheadgene Power Supplies 93 27th September 2005 12:12 PM
Copyright 1999-2017 diyAudio
