How to mount a toroidal transformer vertically?
Old 25th September 2013, 12:50 AM   #21
TonyTecson is offline TonyTecson  Philippines
TonyTecson's Avatar
^done that way ensures trouble....
unless nylon plastic shoulder washers are used to insulate at least one end of the U-bolt....
http://www.ebay.com/itm/500-pcs-1-4-...-/150500411920
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 18th October 2013, 05:58 PM   #22
Apex Jr is offline Apex Jr  United States
Originally Posted by toxic ingestion View Post
I went to your web site and didn't see these. Could you provide a link directly to these items?
Thanks.
They measure 4 1/2" Tall and 3 1/4" Wide with a 2" indent
Old 8th November 2013, 09:11 PM   #23
hotironsmoke is offline hotironsmoke  United Kingdom
My case was pretty sturdy, so I just bolted it to the casing using the supplied securing disc and bolt. I used a rubber disc to buffer the windings against the case.
Old 11th February 2014, 12:42 AM   #24
BobEllis is offline BobEllis  United States
BobEllis's Avatar
Somewhat old thread, but since I just bought some brackets in post 6 and 22 from Steve at Apex Jr.Home Page I thought I'd let anyone interested know that his brackets will mount an Antek 4220, or any other 5.1" diameter transformer. There's not a lot of extra room, but on the plus side, the bracket is stiffer than it looks in the picture.
Another happy apexjr customer. Ordered Thursday, changed the order before it shipped, and got it Monday.
Old 11th February 2014, 01:21 AM   #25
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
I went to Wickes (our local builders merchant) and bought some 65 x 90mm pre-drilled steel brackets - less than 2 each.
How to mount a toroidal transformer vertically?Hide this!Advertise here!
Why you should mount your SiC mosfets vertically d to the g Pass Labs 9 23rd July 2013 01:27 AM
Mount rectifier above torroidal transformer? platplaas Tubes / Valves 13 28th February 2011 05:10 AM
Electrical safety with pcb mount transformer diycore Construction Tips 6 9th September 2009 10:35 AM
PCB mount line input transformer question audiowize Tubes / Valves 0 11th July 2008 08:05 PM
