Resettable fuses in power rails thoughts - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 15th September 2013, 07:05 PM   #11
Mooly's Avatar
Originally Posted by Aucosticraft View Post
can we think of some relay circuit that will disconnect power rails when high current flows. and switch on back after certain time?
What if the high current were a short. The relay would then try and re-connect the rails into that short. Also the relay control circuit would need to be fed from a reliable independent supply.
Installing and using LTspice IV. From beginner to advanced.
Old 15th September 2013, 07:14 PM   #12
I agree....... but then we have slow blow fuse too. and if the slow blow fuse too blows off then, we can feel sure that it is dead short. ( the slow blow fuse will blow off after couple of relay resets.)
Add: OR we can say, depending on the current flow , relay should determine, if it should reset.
There is always a first time....
Old 15th September 2013, 07:18 PM   #13
Mooly's Avatar
Complicated... you would have to sample the current and have some means of determining if the relay should operate again based on the current that actually blew the fuse.
Old 15th September 2013, 10:47 PM   #14
DUG is offline DUG  Canada
If you have a fast acting circuit disconnect then how are you going to set off a slow blow fuse?
Have you ever had a computer power supply that just kept chirping every second or two?
That is an automatic retry on an over current or short circuit situation.
With analog circuitry you can do as I suggested in post #5 and with added digital decision making (4 tries and stop) you can stop it from starting again until an operator reset occurs.
Nothing new here.
But do you need it in your amp?
If you really do then go for it...I will help where I can.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Benefits/Drawbacks of Dual rails vs Single Rails buzzforb Pass Labs 2 25th May 2011 02:06 PM
Power Acoustik TS980 sparks, blows fuses even without power on. BoeroBoy Car Audio 7 30th September 2010 03:17 PM
build power supply for35vdc rails doggy Power Supplies 17 10th January 2006 05:56 AM
Fuses, primary, rails, current limiters and channels? rgrayton Chip Amps 4 5th August 2005 05:15 PM
Raychem resettable fuses jackinnj Everything Else 5 17th January 2003 09:47 PM
Copyright 1999-2017 diyAudio
