Regulated Negative Power Supply
Old 13th September 2013, 01:25 PM   #21
sghr220 is offline sghr220
Originally Posted by KatieandDad View Post
You need to address the transformer before you think about the caps. The transformer is just not adequate in this circuit unless you dispense with the regulator.
I can do just fine with +-25 to +-27 voltage output at 5A. Click the image to open in full size.
Old 13th September 2013, 01:25 PM   #22
KatieandDad is online now KatieandDad  United Kingdom
KatieandDad's Avatar
3 x 4700uF per rail will work well if you dispense with the regulator.
If you want to persist with a regulated supply you will need a higher voltage transformer.
Old 13th September 2013, 01:29 PM   #23
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Remember the transformer has some regulation too. Let us assume it is around 7% at the stated 480VA...
Old 13th September 2013, 01:34 PM   #24
You could use a CRCRC PSU to drop a few volts.
Old 13th September 2013, 01:50 PM   #25
I pretty much appreciate your advice but a variable regulated split power supply will give much versatility in powering low to medium power chip amps don't you think.
Old 13th September 2013, 01:52 PM   #26
What part of this are you not reading. Your transformer is too small to feed a regulated supply.
It would be suitable for a 24V regulated supply at its VERY BEST. That would require massive pre-reg capacitors in order to keep the pre-reg ripple under the Vin requirement of the regulator.
Old 13th September 2013, 02:01 PM   #27
What part of this are you not understanding? I repeatedly stated that i don't need a FULL 30v, and about the 24v or the 18v that's you guessing right?
Old 13th September 2013, 02:04 PM   #28
I give up. Try doing a bit of homework.
Old 13th September 2013, 02:09 PM   #29
Try some etiquette will you?
Old 13th September 2013, 02:11 PM   #30
You have 2*24VAC at 480VA
You have therefore 2*36VDC at no load condition.
This drops to 2*33VDC at full transformer power.
Regulated Negative Power SupplyHide this!Advertise here!
Regulated Vs Non-regulated linear Power Supply mbeards Tubes / Valves 2 30th January 2013 09:45 PM
Negative and positive regulated supply:same winding? bullpeters Power Supplies 3 4th July 2012 05:59 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 05:17 PM
Negative Effects of external power supply? pjpoes Solid State 7 31st May 2007 11:37 AM
Low Power Negative Car Power Supply Alcaid Car Audio 3 11th December 2003 03:32 PM
