Regulated Negative Power Supply
Old 13th September 2013, 01:55 PM   #11
macboy is offline macboy  Canada
Just saw the notes about voltages, and I agree with Katieanddad about the headroom. You need more than 33 or 34 V at the input if you want to have 30 V @5 A at the output. Generally more headroom is required when using a transistor boosted circuit. You will likely need to reduce the output to something like 27 V or get a different transformer.
Another option may be to use low dropout regulators. But you would need to use a few in parallel, and I don't know how well they behave like that (LDO regulators are tempermental at the best of times).
Old 13th September 2013, 01:58 PM   #12
sghr220 is offline sghr220
Originally Posted by macboy View Post
Your circuit has errors and will not work as intended. Have you tried simulating it?
Yes i did and it worked quite fine actually.
You have mis-connected some things on the output side of the LM337.
Like what exactly?
Try a google image search for something like LM337 high current or LM337 transistor, and you will find plenty of working examples of what you tried to do here.
Did that but all i can find was the lm317 circuit or the positive half of the power supply.
Old 13th September 2013, 01:59 PM   #13
Originally Posted by sghr220 View Post
Sorry i didn't understand the Vbe part
VBE is Voltage across the base-emitter junction of the transistor (Q7 in your schematic). You will need to find what VBE should be at 5 A output current (a.k.a. IC) by examining the datasheet for the 2SA1943. (Hint: Toshiba datasheet, page 3, "IC - VBE" graph).
Old 13th September 2013, 02:06 PM   #14
Unfortunately, simulations often don't find common mistakes like flipping the emitter and collector. Plenty of simulated transistors work very well backwards. Most real BJT transistors work to some extent backwards, but not well.
Old 13th September 2013, 02:09 PM   #15
I can do just fine with +-25 to +-27 voltage output at 5A.
Old 13th September 2013, 02:09 PM   #16
Try googling:
lm337 high current site:electronics-diy.com
Old 13th September 2013, 02:11 PM   #17
Measuring the voltage between the base and emitter in the simulated circuit gives -0.99V.
Old 13th September 2013, 02:13 PM   #18
Fortunately they do.
Old 13th September 2013, 02:15 PM   #19
Try googling:
Thanks for the pointer, but can the 3055/2955 be swapped with the Sanken pair. And also what about the capacitors arrangement and values.
Old 13th September 2013, 02:23 PM   #20
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
You need to address the transformer before you think about the caps. The transformer is just not adequate in this circuit unless you dispense with the regulator.
Regulated Negative Power SupplyHide this!Advertise here!
Regulated Vs Non-regulated linear Power Supply mbeards Tubes / Valves 2 30th January 2013 10:45 PM
Negative and positive regulated supply:same winding? bullpeters Power Supplies 3 4th July 2012 06:59 AM
Power supply positive-negative-ground from a single power supply mome Power Supplies 8 9th September 2011 06:17 PM
Negative Effects of external power supply? pjpoes Solid State 7 31st May 2007 12:37 PM
Low Power Negative Car Power Supply Alcaid Car Audio 3 11th December 2003 04:32 PM
