effects of faulty lm78xx? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 13th September 2013, 11:08 AM   #11
weird. i tried different caps, new reg, rerouted grounding and nothing seemed to work until i decided to use pin 1,2 of the hex inverter instead of 12,13 which i had been using because of my terrible layout.
Old 13th September 2013, 11:42 AM   #12
never mind. the problem reappeared after an hour. could even the smoothing cap cause this? i'm using salas shunt with once again, recycled caps.
Old 13th September 2013, 01:44 PM   #13
when the distortion starts, i can kill it by changing the value of the variable resistor for lm317 that feeds the te7022 usb module. so it's not the hex inverter where the distortion is from. my grounding scheme is a mess. i will try to star ground everything. do you think it might be parasitic oscillation?
denom pma250 amp faulty,but no faulty parts found please help homertooties Solid State 1 7th December 2008 03:58 PM
Problems with LM78XX regulators??? Minion Power Supplies 8 12th May 2007 04:38 PM
LM78xx LM79xx Spice models? sam9 Software Tools 3 27th March 2004 07:49 PM
Slow turn-on for LM78XX regulators? JojoD818 Solid State 0 15th February 2004 11:16 AM
Copyright 1999-2017 diyAudio
