12 volt power supply
Old 8th September 2013, 10:51 AM   #1
stoppage is offline stoppage
Default 12 volt power supply
I need to invert +12 volt to - 12 volt dc so that I can use both for op-amps. How please?
Old 8th September 2013, 02:47 PM   #2
Minion is offline Minion  Canada
Maybe explain in more detail what you want to do . Like why do you need -12v ??
Old 8th September 2013, 03:11 PM   #3
John8 is offline John8  United Kingdom
If it is just for a couple of op-amps have you looked at the ICL7660A voltage multiplier chip run in the inverting mode. This will generate -12V from +12V.
Alternatively use a +6V supply as a virtual ground for the op-amps if you don't need a large voltage swing.
Old 8th September 2013, 03:17 PM   #4
gootee is offline gootee  United States
Is it for a bench supply, or an automotive application, or a portable (batteries)?
If it's just for use where there are wall outlets, or for "lab" use, you can use two 12v wall warts and connect the negative of one to the positive of the other and call it ground.
Old 8th September 2013, 04:24 PM   #5
Most op amps, e.g. TL071 run on "dual rail" (e.g. + 12 and -12 volts) I have +12. Need - 12 for TL071
Old 8th September 2013, 04:51 PM   #6
How much current or power is available from your existing 12-Volt supply? What type of supply is it?
Also, there are several other possible (and possibly better) ways to obtain or build a bi-polar bench supply. Are you looking for the cheapest way, or the easiest way, or would a better way be something that you would want to consider?
Old 8th September 2013, 07:58 PM   #7
dangus is offline dangus  Canada
I might be tempted to buy a DC-DC converter module. For maximum quality, I'd use one with +/-15V outputs and regulate down to +/- 12V with linear regulators.
MC34063 switching regulators are found in nearly every car cellphone and USB charger. The application note clearly shows how to hook one up for negative output, and board layouts are provided, if you can't easily alter the charger layout.
http://www.onsemi.com/pub_link/Colla...MC34063A-D.PDF
Old 8th September 2013, 08:02 PM   #8
Frank Berry is offline Frank Berry  United States
Frank Berry's Avatar
Most opamps are very happy with + and - 15 volt supplies. No need to regulate them down to + and - 12 volts.
We really need more information from stoppage so that we can understand why he can't just use a bipolar supply.
Frank
Old 8th September 2013, 08:49 PM   #9
P { margin-bottom: 0.08in; } „S-60-15 - 60W 15V 4A Enclosed Switching Power Supply“
Its a 15 volt adjusted down. I just need a reasonable-quality - (minus)12/-15 volt supply for opamps so that I don't have to bother with "virtual earth" etc
Old 8th September 2013, 09:08 PM   #10
sofaspud is offline sofaspud  United States
sofaspud's Avatar
An inverter IC is likely your best bet. Even the 555 will do the job, and there are many others, for instance the ICL7660 and MC34063 already mentioned. Maxim, On Semi, TI, etc. probably all have a few varieties.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
12 volt power supplyHide this!Advertise here!
TDA8947J output power@12 volt supply sudhir kumar Chip Amps 18 26th February 2014 11:28 AM
12 volt power supply for tube amps caraudionut Tubes / Valves 9 27th April 2007 03:04 PM
how to build a 12 volt dc power supply? michelevit Class D 5 22nd December 2006 07:53 AM
How to use a 220 Volt power supply at 12 Volts in the car? Mr. Old School Car Audio 3 10th March 2006 12:11 AM
Suitable chip for 12 volt indoor supply Winnie Chip Amps 28 16th September 2004 09:44 AM
