Can you do this safely? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 25th August 2013, 05:53 PM   #1
Default Can you do this safely?
Analogous to how some would put separate power supplies in parallel, could one also do this with a CT'd transformer?
I realize voltage dropped across resistor and cap size, etc. makes a difference, but those variables aside, can the circuit appear as does in the drawing without breaking anything?
Also, assuming between each secondary and CT there is 1 amp of potential, does this give me a overall net 2 amps when connected this way?
Old 25th August 2013, 07:18 PM   #2
sofaspud's Avatar
No.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 25th August 2013, 07:21 PM   #3
If I could be so bold as to ask, Why not?
Old 25th August 2013, 07:28 PM   #4
sofaspud's Avatar
You're trying to put the out of phase secondary outputs in parallel. That won't work. I think you'll find a biased-on-diode short if you follow the current flow through that circuit.
Old 25th August 2013, 07:28 PM   #5
Thank you for the reply and the information.
Soldering tweeters.. how to do safely? GeneZ Multi-Way 54 4th August 2016 03:53 PM
Safely packing your equipment jackinnj The Lounge 1 17th August 2013 12:16 AM
How old electrolytic capacitors can safely be used? TB Power Supplies 6 16th August 2011 12:10 PM
how much capacitance can i add safely? Clipped Car Audio 8 28th September 2007 10:40 PM
Copyright 1999-2017 diyAudio
