Power Supply for Tube Preamp - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 10th August 2013, 07:50 PM   #1
Default Power Supply for Tube Preamp
Hello again, I was wondering if anyone has ever made a quiet tube rectified power supply for a Tube preamp?
I'm looking to provide 300 VDC, at 50 milliamps. I already have an Edcor Transformer, 5AR4, 22uf 500 volt, and then Hammond 10H 100m choke, that I will feed several PI filters to bring the rippled and voltage down.
However, whenever "I" build a supply like this, I still have a decent amount of noise present. This could be ME< or it could be the supply- I don't know.
But I'm thinking that regulating that 300 VDC is the way to go, perhaps with a chip?
That's what I'm looking to you folks for advice for.
Any ideas welcomed:-)
Aric
Old 11th August 2013, 07:54 PM   #2
DF96 is offline DF96  England
Do you mean noise or hum/ripple? Most people routinely get the grounding wrong when building a PSU. Adding extra smoothing sections then makes no difference, apart from the cost and size.
Old 11th August 2013, 08:23 PM   #3
Elvee is offline Elvee  Belgium
Elvee's Avatar
22µF looks a bit flimsy for the task of smoothing 50mA, but anyway, it doesn't make much difference: even if you increased it to 100µF, it would only bring a ~12dB improvement, which is sizeable but not enough to gain complete quietness.
This means that DF96's explanation is probably right: there must be something wrong in your wiring. Probably the ground, but there may be other possibilities too.
If you post your exact circuit, it can be simulated to evaluate how much ripple you'll really incur (with a perfect wiring).
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 11th August 2013, 08:36 PM   #4
RJM1 is offline RJM1  United States
You could use something like this.
MOSFET Regulator
But You would have to change the mpas92,42 to mpsa94,44 and the feedback resistor R9 to about 68K.
Old 11th August 2013, 11:19 PM   #5
funk1980's Avatar
Check out the 'Maida regulator'. It's a LM317 regulator used in a configuration to allow for high voltages. Good performance, low parts count and a proven design. I've build several with great results. My current preamp (2x 12ax7) uses one at 325V. I don't have the exact numbers at hand, but the ripple is in the few milivolt range. Morgan Jones (I own the 3rd edition) has a great section on the design, but lot's can be found here on the forum and elsewhere online.
Old 12th August 2013, 09:05 AM   #6
merlin el mago's Avatar
My advice diy Salas Simplistic HV version 2: Simplistic Mosfet HV Shunt Regs
Old 12th August 2013, 02:45 PM   #7
Triodethom's Avatar
pics and a schematic would help with troubleshooting your problem. Regards
Old 14th August 2013, 01:21 PM   #8
Default Schematic Image
Thanks for the replies and sorry for the delay. I'm going to try the PSU in a seperate chassis, with an umbilical cable to the preamp, with conductors of 14/4.
The plan is to send 12 VDC down two wires of the cable, and the 300 volts down the other two.
The preamp has 4 separate channels, 2 are 12ax7 phono stage left and right, and the other 2 are 12ax7 line level preamp channels.
This is a continuation of a project I was building a few weeks back which I decided to scrap.
I am laying out this one from scratch, and really want to get the noise floor down as much as possible.
Please ignore the SS rectifier supply in the drawing I will not be using that, but rather will be using the Tube Rectified version above it.
The second picture is an RIAA stage for the phono that I am implementing into the desgin.
Old 14th August 2013, 02:00 PM   #9
Triodethom's Avatar
I would use the choke with SS as well as the tube rectifier . That would let you increase the cap value without increasing the peak load on the transformer average would be about he same.
Old 14th August 2013, 02:59 PM   #10
Elvee's Avatar
With such a filter, the noise will be vanishingly small: it is below the default resolution of LTspice.
Since the p-p ripple on C3 is ~215µV and the final RC brings an additional 60dB, the result should be 215nV. Unlikely to cause problems. If you still get hum, that simply means there is something wrong in the wiring.
Note that the supply will be capable of providing only 2.3mA for a 300V output.
From a purely academic perspective, the circuit is improvable: if you make R4 and R5 approximately equal (15K + 18K for example), you will gain a few tens of dB quietness, should that matter...
Low cost compact power supply for sub-mini tube preamp johnmac0117 Power Supplies 10 8th May 2011 10:48 PM
Tube Preamp Module and Power Supply PCB's Geek Swap Meet 47 31st January 2009 09:48 AM
looking for hv power supply kit for car tube preamp tomat Parts 6 7th December 2008 03:48 AM
WTB:power supply for tube preamp dariusku Swap Meet 0 18th September 2006 07:04 PM
power supply for tube preamp rafafredd Tubes / Valves 11 15th November 2002 04:32 PM
Copyright ©1999-2017 diyAudio
