Toroid Rewind
Toroid Rewind
Old 9th November 2013, 02:33 PM   #11
Kay Pirinha is offline Kay Pirinha  Germany
Kay Pirinha's Avatar
Originally Posted by hotironsmoke View Post
What I often wonder is, would there be advantages in segregating the secondary windings to separate segments of the toroid, or conversely shared evenly.
No. Due to better coupling and mimimalizing magnetic leakage, all windings should be done fully circumferentially. So it is better to wind the low voltage heater winding(s) on top of the plate supply winding.
Best regards!
Old 9th November 2013, 02:56 PM   #12
KatieandDad is offline KatieandDad  United Kingdom
KatieandDad's Avatar
The magnetism is uniform around the toroid and it is usually accepted to try and keep it that way by spreading each secondary and indeed the primaries evenly around the core.
Toroid RewindHide this!Advertise here!
Rewind primary 100v/240v? redrooster Power Supplies 7 28th January 2013 04:43 AM
Rewind on existing voice coil Datubie Multi-Way 0 3rd November 2008 11:58 PM
Fender Bassman PT Rewind OKBill Instruments and Amps 4 14th January 2007 02:51 PM
Reuse or rewind choke mashaffer Tubes / Valves 1 15th July 2005 04:28 PM
Help. Can I rewind speaker voicecoil chris wood Multi-Way 8 10th March 2004 01:08 AM
