Symmetrical power supply with two identical sources - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 14th July 2013, 02:46 PM   #1
Project16's Avatar
Default Symmetrical power supply with two identical sources
Hi everyone!
I plan to make a regulated power supply with two symmetric positive sources but I'm not sure my idea.
To explain a little, there would be a plate with a small adjustable control transformer and power sources with another transformer, filtering, etc ...
I made a pattern but there must be problem I think.
Regards!
Old 14th July 2013, 09:30 PM   #2
DF96 is online now DF96  England
What you have called 'power cap' is actually a reservoir cap. The bottom part of the circuit needs one too to drive the regulator.
Old 14th July 2013, 09:38 PM   #3
DUG is offline DUG  Canada
The two top ground symbols should not be connected to the bottom two ground symbols.
And what DF96 said.
Doug We are all learning...we can all help
"You can't stop the signal, Mal. Everything goes somewhere..."
Old 14th July 2013, 10:14 PM   #4
benb is offline benb  United States
And one more thing, you can't tie the bases of those transistors together like that and expect it to work.
You've got the idea of making a + and - regulated tracking output supply, but as you surmised by saying "there must be a problem," you're not quite doing it right.
Old 14th July 2013, 10:22 PM   #5
oops, missed that
use symmetrical transformer for single supply amp? tsiros Power Supplies 32 8th September 2012 08:34 AM
+/- 85 volts symmetrical power supply xeclipse Solid State 3 23rd May 2010 06:29 AM
symmetrical supply PLH amp umut1001 Pass Labs 5 2nd April 2008 04:03 AM
Symmetrical supply rails with a 2 wire transformer, is it possible? Bricolo Parts 14 4th March 2003 10:09 AM
Copyright 1999-2017 diyAudio
