Question About Transformer Voltage Output - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th July 2013, 08:00 PM   #1
Wink Question About Transformer Voltage Output
Good evening everyone,
I am putting together a small DC power supply with simple bridge rectifier and smoothing caps.
The traffo I got is rated at 100VA - 30V
this one from Farnell
RK100/30 - BLOCK - TRANSFORMER, 100VA, 2 X 30V | Farnell United Kingdom
When connected to the mains (230V in UK), instead of 30VDC at the output of the capacitor's bank, I get around 44VDC?
I have tried with the secondaries in parallel, and with just a single secondary...
Same result...
Am I missing something?
(Please don't be too harsh in case I did, as it is my first serious foray into PSUs.)
Thanks for your enlightened help everyone!
Cheers
Francois
Old 5th July 2013, 08:39 PM   #2
sofaspud's Avatar
30V is the RMS voltage of the transformer secondary when it is delivering 100VA.
The capacitor bank is charging to the peak voltage of the transformer secondary, minus losses (eg, in the rectifiers and connecting wires).
The circuit is functioning as it should.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 5th July 2013, 08:46 PM   #3
nigelwright7557's Avatar
30volts is only 0.707 of the peak AC voltage.
So 45 volts is about right.
Murton-Pike Systems PCBCAD51 pcb design software. http://www.murtonpikesystems.co.uk
Old 5th July 2013, 08:52 PM   #4
KatieandDad's Avatar
30V is the AC voltage. You will get approximately 1.414 x 30 volts after rectification, you will lose the 0.7V of the diode drops but at 30V that's almost insignificant.
Old 5th July 2013, 09:50 PM   #5
Oh, I see...
I should have checked my theory books first!
I does make sense now.
Thanks everyone
F
Old 5th July 2013, 10:33 PM   #6
TonyTecson's Avatar
load your psu and the voltage will sag...guaranteed....
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 6th July 2013, 09:42 AM   #7
Output voltage ~ Mains voltage / rated primary voltage * rated secondary voltage * [1+regulation].
For a 230:30Vac transformer of 7% regulation expect when used in the UK to give ~ 240/230*30*(1+7%) ~ 33.5Vac.
The peak of the sinewave will be sqrt(2) * Vac = 47.36.
From this you need to subtract the voltage drop (Vf) of the bridge diodes. say 1Vf for a no current load and the rectified output will be ~ 46.4Vdc from your 230:30 7% transformer.
The maximum voltage using the UK's 254Vac will be ~ 49.1Vdc. Just about the absolute limit for {Vdc + V interference} of a 50V capacitor.
regards Andrew T.
Sent from my desktop computer using a keyboard
What happens when Output transformer max voltage (slightly) exceeded? walangalam Tubes / Valves 20 17th April 2013 02:02 AM
Can An Output Transformer Change A Voltage Amp's Output Impedance From 0.1 To 47 Ohms kelticwizard Everything Else 11 25th March 2007 05:17 AM
Lowering voltage output of transformer TGRANT Tubes / Valves 8 17th January 2007 10:29 AM
Help:How To Reduce Transformer Output Voltage? phill77 Solid State 0 21st April 2003 12:04 PM
Copyright 1999-2017 diyAudio
