Need some help understanding - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 4th July 2013, 03:22 PM   #1
Default Need some help understanding
Hallo all,
Plse help me understand this. I have a toroidal 500 VA with dual secondary outputs, 0-48, 0-48 VAC. When I connect them to a rectifier bridge, the voltage after the bridge is +- 45VDC on each winding. When I add 10000 uf EL caps after the bridge, I get 66VDC. So 48 x 1.414= 68.8VDC - 0.7Vd due to the bridge which is correct. My question is, why do I only get 67VDC after the caps are added ? I am using a Fluke true RMS meter.
Jan
Old 4th July 2013, 03:45 PM   #2
what are the tolerances of the capacitors you are using??
Old 4th July 2013, 03:53 PM   #3
Frank Berry's Avatar
Two diodes on each side of the bridge for a total of 1.4 volts drop.
Frank
Old 4th July 2013, 04:03 PM   #4
Vrystaat, not sure I understood your question: are you asking why don't you get 67VDC without the CAPS ?
If that is the case, it is because the average of a full-rectified is 2*Vpeak/pi=2*(48*1.414-2*0.7)/pi = 42V (assuming vdrop in each diode of 0.7V ).
When you introduce the CAP you'll get an almost DC output, whose average is near the rectified sinewave's peak value (~66V)
Old 4th July 2013, 04:30 PM   #5
Thanks to all, the lights suddenly came on !! It makes sense now.
Jan
Help with schematic understanding sumo Tubes / Valves 6 3rd May 2009 12:07 AM
Help understanding this crossover larryfff Multi-Way 5 18th February 2008 09:34 PM
Would like a better understanding of a 2.5-way design tf1216 Multi-Way 3 14th February 2008 06:19 PM
non-understanding oversampling Bernhard Digital Source 26 3rd March 2007 10:32 PM
help understanding a crossover...? Yoda Multi-Way 3 12th January 2002 07:10 AM
Copyright 1999-2017 diyAudio
