What´s noise floor in audio amplifier? - diyAudio
Old 20th June 2013, 04:22 AM   #1
OMARDUENAS is offline OMARDUENAS  Colombia
OMARDUENAS's Avatar
Default What´s noise floor in audio amplifier?
What is this noise in the audio signal?
What affects the audio signal?
Old 20th June 2013, 05:42 AM   #2
Joachim Gerhard is offline Joachim Gerhard  Germany
Joachim Gerhard's Avatar
Type of transistors used, especially in the input stage.
Idle current, also most important in the input stage.
Gain structure.
Power Supply rejection, grounding, to name a few.
Old 20th June 2013, 07:46 AM   #3
DF96 is offline DF96  England
Thermal noise too. That sets the base below which it is impossible to go.
Old 20th June 2013, 08:26 AM   #4
Yes, and then is the issue if low voltage noise or low current noise is required.
Old 20th June 2013, 08:38 AM   #5
thoglette is offline thoglette  Australia
thoglette's Avatar
See also Designing for Ultra-Low THD+N in Analog Circuits
Old 19th July 2013, 04:02 PM   #6
Jsixis is offline Jsixis  United States
I can't study web pages that make me click after every paragraph
Old 20th July 2013, 10:41 AM   #7
Print them off and read at your leisure.
Add interference noise to those lists.
regards Andrew T.
Sent from my desktop computer using a keyboard
Noise floor of Tubelab SE Nikon1975 Tubelab 30 29th November 2012 08:38 AM
noise floor analyser vincent_brient Vendor's Bazaar 6 19th September 2011 08:57 AM
tripath noise floor. lbstyling Class D 10 23rd September 2010 04:54 AM
What makes an amplifier have a lower noise floor? pjpoes Solid State 27 2nd July 2007 12:20 AM
noise floor problem johndiy Solid State 12 31st August 2006 01:32 AM
Copyright ©1999-2017 diyAudio
