detex audio smps xp-5000watts
Old 3rd January 2014, 12:25 PM   #11
ANGELPRO is offline ANGELPRO
Default smps circuits
schematic smps the good circuit,
please send to my email astra1_2008@yahoo.com
thank you brother,,.
Old 5th January 2014, 12:23 AM   #12
fhoenix is offline fhoenix  United States
please send
to my email aw4n_1988@yahoo.com thanks
Old 4th February 2014, 11:12 AM   #13
Hyper2283 is offline Hyper2283  Romania
please send
to my email the pcb miky_2283@yahoo.com thanks
Old 8th February 2014, 02:14 PM   #14
gothye1984 is offline gothye1984  Poland
I also please send rafal.szewc84@gmail.com
Old 10th February 2014, 05:55 AM   #15
aman khalsa is offline aman khalsa  India
aman khalsa's Avatar
Default here is the sachmatic .....
Old 11th February 2014, 11:45 AM   #16
netiks is offline netiks  Azerbaijan
Please Post PCB file for this 5kw smps
Old 14th February 2014, 03:49 PM   #17
Why is this design not good Im reading that a lot of people doesnt like selfoscilating smps? is it that bad? dangerous?
Can somebody explaine to me?
thanks
Old 14th February 2014, 06:21 PM   #18
Is this smps with soft start or no?
Old 10th April 2014, 04:52 PM   #19
eltonseemann is offline eltonseemann  Brazil
What is this topology? Not is half-bridge. 300 volts are applied to the primary, I'm uncertain about the ratio of turns between primary and secondary. In one cycle it applies 300V and other it resets the transformer?
Old 14th April 2014, 10:44 PM   #20
I mounted the above schema and works.
The polarity of the gate driver is the opposite of Layout1. It is as described in scheme 2 handmade.
Ran 44KHz and I will have to increase the number of turns of the transformer because my saturated and heated. I used 19 turns on a toroid with 1.95 cm2 of Ae, which would give 2300g. I will increase to 30 turns and stay in 1500G.
It really is half-bridge, I was confused because one leg missing capacitor voltage divider (between transformer and negative), but the voltage ratio is like a voltage divider. I used 11 +11 turns on the secondary and got 85V +85 V
detex audio smps xp-5000wattsHide this!Advertise here!
Big power 2500-5000watts SMPS for power amplifiers DjLeco Swap Meet 10 28th December 2012 10:08 AM
SMPS for audio. Boscoe Power Supplies 23 4th January 2012 08:12 AM
SMPS for Audio Q's weinstro Power Supplies 10 8th June 2010 01:06 PM
FIX For M-Audio Drivers for XP sp3 xdurus Digital Source 0 29th June 2008 06:11 AM
LC AUDIO MILLENNIUM XP - HELP if possible from Lars Clause! andythefirst Solid State 30 19th May 2008 06:46 AM
