Go Back   Home > Forums > Amplifiers > Power Supplies
Old 1st June 2013, 08:04 PM   #1
Default All I've got is a scope - how do I measure PS stability?
I have the usual assortment of small test tools, but for big stuff all I have is a Tek 2465A. Have 1x and 10x probes. I'm trying to figure out how much I can do to measure PS stability using a scope.
I have dummy loads to get a PS to drive the expected current, but once I have that set up... what do I do? Just measure it DC coupled to see if the DC out is stable? Do some sort of examination AC coupled?
Old 1st June 2013, 08:22 PM   #2
Elvee is offline Elvee  Belgium
Elvee's Avatar
A possibility is to use a small auxiliary supply adjusted to the same voltage as the supply under test. You then use this supply as a ground for your scope, preferably set to the max gain with x1 probes, it will act as a magnifying glass during your tests, even in DC.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 1st June 2013, 09:22 PM   #3
Elvee, this sounds interesting. I do happen to have a HP adjustable DC lab supply , but I'm not sure I understand. Are you saying that I set that supply to +5V (that's the same as the PS I want to test) and then tie the ground side of the probe to the + side of that supply?
Old 2nd June 2013, 06:44 AM   #4
Elvee's Avatar
Yes, just be careful that earthings do not come in the way of what you intend to do, otherwise you may short the supply.
Old 2nd June 2013, 08:23 AM   #5
Cant the scope be ac coupled ? Its bad practice to float the scope ground but i guess youll be fine if its only 5v
Can your electric loads do steploads?
Old 2nd June 2013, 11:36 AM   #6
Okay. So I have the scope probe + and - across the + and - of the DC supply I wish to test. I have the + of the floater supply connected to the - of the probe/DUT. What do I do with the - of the floater supply? Leave it disconnected?
I'm not sure what this will get me with respect to testing PS stability.
Yes Tazzz, the Tek can be AC coupled. I have various resistors to allow for a check across various output currents.
Old 2nd June 2013, 03:29 PM   #7
Elvee's Avatar
Connect the two (-) together, see schematic.
If your aux supply remains stable, you will see the behavior of the main supply with the max sensitivity of the scope (2mV/div f.e.).
Using AC coupling, you can do the same, but for AC only which is less practical.
The output loop has to be connected to a single earth point (probably the scope, otherwise you will short something
Old 2nd June 2013, 04:32 PM   #8
Thanks Elvee! But I'm not sure I understand this part.
Old 2nd June 2013, 04:46 PM   #9
WSJ is offline WSJ  United States
WSJ's Avatar
Transient Recovery Time. Sometimes referred to as recovery time, transient response time or response time. The time required for the output voltage of a power supply to come back to within a level approximating the normal DC output following a sudden change in load current.
Transient recovery time on Page 12, 109 & 110
http://cp.literature.agilent.com/lit.../5952-4020.pdf
Old 2nd June 2013, 05:14 PM   #10
Got it. Thanks. Something that can't be measured in the AC realm.
How to measure JLH Class A with a Scope chris ma Everything Else 84 28th December 2012 08:13 PM
Can I use a scope to measure powerline noise? Saurav Parts 23 11th July 2012 06:37 PM
Inverting regulator (-ve rail from +ve supply) - current requirements? peskywinnets Solid State 10 7th October 2010 01:53 PM
Want to measure µV on the scope: should I buy a new one or build a low noise preamp? Bricolo Parts 43 1st November 2005 08:41 AM
Can I look for (or even measure) distorsion on an amp with a dual scope? Bricolo Parts 17 17th September 2003 02:06 PM
vBulletin Optimisation provided by vB Optimise (Pro) - vBulletin Mods & Addons Copyright © 2014 DragonByte Technologies Ltd.
Copyright ©1999-2014 diyAudio
