Quick primary check pls (diagram)
I called the manufacturer, and got the primary voltages for each wire on this power transformer.
Is my diagram correct for typical 120v/60Hz ? (USA)
(700VA) !!
Choices:
A) yes.
B) no.
C) no, but try it....you should know this stuff by now.
D) Yes, but after converting the 72v secondaries to DC, you will possibly die a noble death.
Thanks AndrewT and DF96, I will.
BTW, This transformer is the "MARK LEVINSON Toroidal Transformer Ultra- Low Noise" found on eBay (US).....so if anyone is wondering the what the primary wires are, these are them. (slide the sheathing down, to see wire colors).
