Transformer specs? - Page 4 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 24th May 2013, 11:38 PM   #31
TonyTecson's Avatar
just a guess, about 75va...
planet10 needs your help: Let's help Ruth and Dave...http://www.diyaudio.com/forums/plane...ml#post5010547[B
Old 25th May 2013, 05:04 PM   #32
how many volts do you want the power supply for your gainclone circuit? If you are trying to draw more than 12 volts, you probably need another transformer because it looks way too small. What are the dimensions?
Old 25th May 2013, 06:29 PM   #33
Legth: 11cm
Hight: 5cm
With: 8cm
I was thinking about 15-20. Could it then maybe be used in a dual mono amp?
Old 25th May 2013, 08:24 PM   #34
The measurements are ok, although if you are drawing a lot of current then you would need a bigger one
Old 29th May 2013, 01:51 PM   #35
KatieandDad's Avatar
Testing the VA rating of the secondaries is difficult to do accurately and several people have their own ways of approximating what the original design was capable of. In the case of a single secondary you can often use the datasheets of other transformers with similar weight to give you some idea. With multiple secondaries it's down to experimentation.
My method is to load up each secondary until the voltage starts to drop, at the same time making sure that the transformer is still running cool. Ultimately the transformer will fail if any winding overheats.
With a transformer designed to provide driver stages with a higher voltage than the output stages, I would start by seeing what the High Current windings can provide. These can normally be spotted by the thicker secondary wires.
Old 29th May 2013, 09:22 PM   #36
TonyTecson's Avatar
Originally Posted by TroelsG View Post
Legth: 11cm
Hight: 5cm
With: 8cm
are these measurements of the iron(not including the coils)?
if it is, and the 1.7 kg weight tells me you have a fairly sized traffo
good enough for a gainclone....
Old 19th July 2013, 04:11 PM   #37
Jsixis is offline Jsixis  United States
Originally Posted by AndrewT View Post
The bulb tester allows you to safely power up mis-wired primaries.
it is in my view an indispenable tool.
A dual primary or multitapped primary is potentially the most dangerous bit of kit us experimenters can get a hold of.
The bulb tester solves the danger bit.
It even prevents the blown fuse.
I do not test any transformer without a dim bulb tester. I use to, then 1 day I hooked up 120 to a transformer only to learn it was a choke. I fried my power strip, ruined my simpson analog multi meter and arc flashed my eyes.
My dim bulb tester was 2 feet away.
The same thing can happen if the transformer is shorted.
Old 20th July 2013, 08:33 AM   #38
When I joined this Forum, the dim bulb tester (mains bulb tester) did not seem to ever get mentioned.
I asked how to check that the phasing of a dual primary could be wired up safely.
No one came in to suggest using the bulb tester.
It was some years later that I came across this safe method.
I have championed this safe method ever since.
But it does have limitations.
It cannot be used to adjust the output bias of power amplifier.
It does not protect an amplifier that is currently powered up with the smoothing fully charged and a slipped test probe shorts out a critical pair of traces/joints/device legs.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 20th July 2013, 12:51 PM   #39
TonyTecson's Avatar
i build my own traffos...i never used a bulb tester, a simple dmm is all i needed...
Old 21st July 2013, 08:05 AM   #40
AJT,
are you instructing the Membership to never build and never use a mains bulb tester?
regards Andrew T.
transformer specs magelord04 Power Supplies 3 1st August 2007 04:19 PM
Transformer Specs cammy666 Tubes / Valves 1 25th June 2007 09:47 PM
Transformer Specs Gunny Instruments and Amps 1 17th January 2007 05:52 AM
getting the specs on a transformer pango Tubes / Valves 4 18th December 2006 01:39 PM
looking for transformer with the following specs? matthew2456 Tubes / Valves 4 22nd August 2006 09:58 PM
Copyright 1999-2017 diyAudio
