Possible to reconfigure Toroidal Transformer? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd May 2013, 01:07 PM   #11
AJT is offline AJT  Philippines
AJT's Avatar
Originally Posted by jkuetemann View Post
Sure thing.
you'll have to dig out that epoxy in the middle, i do it by cutting the mylar tapes on the outside and the thing will slide off...be very careful not to nick the magnet wires...
now you have to sever the connection point between the 60 and 30 volt taps and make them two separate windings so you can parallel them...
the best advertisement for a good audio design is the number of diy'ers wanting to build it after all the years....never the say so of so called gurus....
Old 23rd May 2013, 01:10 PM   #12
jkuetemann's Avatar
All resistances between adjacent taps are 0.4 ohm.
---Jason Kuetemann---
Power is only granted to those willing to lower themselves enough to pick it up.
Old 23rd May 2013, 01:12 PM   #13
jkuetemann's Avatar
Originally Posted by zeonrider View Post
Here the PSU schematic.
Regards zeoN_Rider
Thanks for the effort zeoN_Rider, I had already sourced the schematics and am aware of what these were used for. Appreciated.
Old 23rd May 2013, 01:14 PM   #14
jkuetemann's Avatar
now you have to sever the connection point between the 60 and 60 volt taps and make then two separate windings so you can parallel them...
I'll read from this that you think it is likely worth a shot. I'm out of time at the moment but will have a look at this later this evening to see. Thanks.
Old 23rd May 2013, 01:16 PM   #15
AJT's Avatar
looking at the pics, it the lead-outs are also the same magnet wired used for winding the traffo, then you are in luck....
Old 23rd May 2013, 02:06 PM   #16
I drilled a few " holes through the filling.
The core pushed out easily once weakened this way.
The insulating wrapping was left intact and undamaged. I needed it for the re-insulation after I had modded the secondaries.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 23rd May 2013, 09:33 PM   #17
jkuetemann's Avatar
OK, It looks like I basically have either four 30V windings or two 30-0-30 in series, depending on how you look at it. Should be straight forward to modify the windings and tappings from series to parallel.
Old 23rd May 2013, 09:35 PM   #18
stoN_Cold's Avatar
Yes, two 30V windings in series 2 times.
Regards zeoN_Rider
Old 23rd May 2013, 10:51 PM   #19
AJT's Avatar
you are lucky indeed, no need to mess with the center filling...
you can feed the primary with 12 volts to get your secondary phasing right...
and if i were you, i'd just install individual pigtails no less than 6 inches long so that absolute flexibility is yours...
toroidal transformer JozzaG Power Supplies 7 13th March 2010 08:16 AM
Cyrus 3 reconfigure for use without PSXR tubenut Solid State 21 1st December 2009 08:18 PM
toroidal transformer djdamix Parts 3 15th June 2004 09:11 PM
Toroidal Transformer sma Solid State 3 3rd February 2004 08:55 PM
Copyright 1999-2017 diyAudio
