7815 and 7915 output problems
Old 17th May 2013, 11:37 AM   #1
Hushang is offline Hushang  Iran
Post 7815 and 7915 output problems
hi all, I built this ps and added a 7815 and 7915 regs at the end of it but.. when I plug both regs i have +15 in 7815reg's out but the 7915's output dosent work, and when I disconnect 7815, 7915 works fine, input is double 32v. help
Old 17th May 2013, 02:42 PM   #2
macboy is offline macboy  Canada
The 7815 input pin should connect to "Red output", it's ground to "A", and the output should be +15V measured to "A".
The 7915 input pin should connect to "Blue output", it's ground to "A", and the output should be -15V measured to "A" (meter's black probe to "A", red to the 7915 output).
Don't forget to notice that the pin configuration of the two regulators is not the same, the 7915 ground pin is not in the middle as it is for the 7815.
Old 17th May 2013, 03:01 PM   #3
R.I.P.
Hush,
looks like D1 & D2 need to be able to pass Fault Current to Chassis.
regards Andrew T.
Old 17th May 2013, 04:28 PM   #4
thanks a lot for reply guys, I checked pins are correct, 7915 "has" output if i disconnect 7815, but when plug 7815, 7915 is not working, is it because of the filters i used?
Old 17th May 2013, 04:41 PM   #5
pfigueiredo is offline pfigueiredo  Portugal
Hi Hushang,
What are the voltages you measure before and after the regulators, in each of the two cases (7815 connected and disconnected) ?
Do you only have the regulators, or any extra hardware ?
What's the load in the regulators ?
Old 17th May 2013, 05:01 PM   #6
Mooly's Avatar
I seem to remember Andrew mentioning a while back that some 79 regs need a minimum load of a few milliamps.
Also consider adding diodes (reverse polarity) between each 15 volt reg output and ground and across each reg to prevent a reverse bias situation if the rails rise at slightly different rates. That can cause a latch up on switch on.
Old 17th May 2013, 05:02 PM   #7
Originally Posted by AndrewT View Post
Hush,
anrew, I did not asemble that part, should I?
Old 17th May 2013, 05:30 PM   #8
Originally Posted by pfigueiredo View Post
Hi Hushang,
tnx alot, without regs i have +/- 34 volts, this ps also have +-34 v output, when i connect both regs +34 and +15 works but other not, why is that so?
Old 17th May 2013, 06:21 PM   #9
What I meant was:
Situation 1: Both Regulators there
Input Voltage of 7815 = ??
Output Voltage of 7815 = ??
Input Voltage of 7915 = ??
Output Voltage of 7915 = ??
Situation 2: 7815 removed
Voltage at Red output = ??
All these voltages measured with respect to node 'A', of course
Old 17th May 2013, 07:29 PM   #10
in sit. 1 :
input voltage of 7815 34
output 15
input voltage of 7915 is 0
output 0
in sit. 2:
about 36
input 7915 about -36 too
output of 7915 about -17.5
7815 and 7915 output problemsHide this!Advertise here!
+/-15vdc 7815, 7915 Power supply argonrepublic Power Supplies 10 13th February 2013 02:11 AM
Replacement Regulators for 7805, 7815 & 7915? goody75 Parts 4 7th July 2011 03:34 AM
7815/7915 dual supply hum problem Lenn Art Power Supplies 8 22nd March 2011 09:57 PM
7815 and 7915, which type A or C? rfenergy Power Supplies 18 18th December 2010 06:54 AM
Pin compatible 7815/7915 replacements? i-s Parts 9 26th October 2010 04:05 PM
