PSU noise - distance between blocks - cables length - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 20th May 2013, 01:21 PM   #11
Frarun is offline Frarun  Poland
I just look at the commercial interfaces to have some reference. If we get e.g. the PATA cable for hardrive connection there is 7 grounds line in the 40-wire version. There are some decoupling between R/W signals like this:
Pin 22 Ground
Pin 23 I/O write
Pin 24 Ground
Pin 25 I/O read
Pin 26 Ground
In 80-wire version the GND is interleaved between every signal. I always though it is just to decrease impact of wires between each other, but this antennas is another reason I think. Anyway with PATA we have some huge transfers, comparing to my microcontroller.
BTW. I always see a problem with I2C transmissions is hearing in the speakers. Not really annoying and only when preamp parameters are changing. But I think it is probably different topic related to loops between digital and analogue GNDs.
Port length vs air movement distance Circlotron Subwoofers 8 26th May 2009 10:32 AM
Long cables from PSU to power amp OK? tcpip Solid State 21 11th October 2006 03:36 PM
AES/EBU coax cables sensitivity to cable length? miksin Digital Source 9 15th August 2006 12:16 PM
PSU for many amp blocks Specterx Chip Amps 8 7th May 2005 07:39 PM
TOSLink Cables All the same? Any degradation over Length? Schmanthony Digital Source 58 21st September 2002 07:33 PM
Copyright 1999-2017 diyAudio
