Control Shutdown (enable) pin of LT1963A voltage regulator with Open collector
Old 12th May 2013, 03:11 PM   #1
coolnose is offline coolnose  Europe
Default Control Shutdown (enable) pin of LT1963A voltage regulator with Open collector
Hi all,
I am trying to put a simple voltage regulator into stanby-mode using an open collector outbput from an atmega.
I am not sure though that the way I achieved this result is very academic - I have not used any pull-up resistor as stipulated in the regulator datasheet as I could not figure out how exactly to do it.
The sim is attached hereunder.
Could someone with more insight kindly point me on how to implement this correctly ?
Thanks in advance,
Max
Control Shutdown (enable) pin of LT1963A voltage regulator with Open collectorHide this!Advertise here!
Unbalance Collector Emitter voltage both pnp and npn EMX_125 Solid State 1 18th May 2010 04:30 PM
LM3886 - regulator on the mute pin ? ash_dac Chip Amps 8 2nd September 2006 01:28 PM
Enable Pin in Tent XO? fmak Digital Source 0 24th May 2006 07:18 PM
Open collector npn output marjan Solid State 5 15th January 2005 07:40 PM
A 3-Pin Regulator Question saurus Solid State 3 27th October 2003 02:54 PM
