Simple regulator sanity check? - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 6th May 2013, 03:15 AM   #1
Yurk is offline Yurk  United States
Default Simple regulator sanity check?
I've put together this schematic of a power supply with three voltages, +/-12v, and +5v. I don't need more than 1amp from any regulator. Does this circuit look correct, or am I missing something? Other than a fuse, I just feel that something's wrong here. Just not sure about running the 5v regulator like that.
Thanks for looking!
Disclaimer: I'm an amateur. I reserve the right to be wrong. Your mileage may vary. Get a second opinion. Maybe a third opinion. etc.
Old 6th May 2013, 03:20 AM   #2
If you are pulling 1 Amp on both the +12 and +5 rails, you are asking the 7812 to pass 2 Amps. It will overheat and shut down.
Use an external pass transistor to boost the current capacity.
Old 6th May 2013, 03:26 AM   #3
GlennW is offline GlennW  United States
Your voltages are confusing. Is the transformer 24 VAC with center tap? With center tap grounded the DC voltages would be approximately +17 and -17. This is ok for 12 V regulators.
Your circuit is ok.
Glenn Wallberg
Old 6th May 2013, 03:40 AM   #4
Yeah, the transformer is around 24vac center tapped/grounded. The 2 amps through the 7812 is maybe what was in the back of my head. Thanks!
Old 6th May 2013, 03:54 AM   #5
sofaspud's Avatar
The 4.7μF caps are somewhat superfluous IMO. The 7805 could be paralleled with the 7812 input, with adequate heat sinking of course.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 6th May 2013, 01:42 PM   #6
Agree completely. I'd also recommend a pass transistor for the 7805 since it will have to dissipate more due the the higher input voltage, and I'd rather dissipate that heat with a transistor.
IMO I'd recommend using a pass transistor for all 3, since I usually don't run more than 500mA in those kind of regulators to keep them well within SOA despite temperature.
You can call me Mad Professor, building crazy experiments in my Electronics Workshop
Old 6th May 2013, 04:54 PM   #7
It's looking more complicated now, but after reading your comments I've added pass transistors and deleted the 4.7uF caps. So, how about this?
Thanks again for the help and ideas!
Old 6th May 2013, 07:48 PM   #8
sofaspud's Avatar
I tend to disagree with the use of pass transistors if the supply isn't required to deliver more than 1 amp at any of the outputs. Any of those regulator chips can easily provide greater than 1 amp with adequate heat sinking.
At the stated power levels, the heat sinks needed don't need to be humongous. The 12V supplies are somewhere around 5W dissipation. The 5V supply is dependent on where it's connected.
Using the pass transistor for the 7812 will allow the 7805 to remain as shown the first configuration. Then you could just connect the 2 regs (7912 & 7805) and pass transistor to identical heat sinks that will each dissipate about 7 watts. Those aren't big sinks, and can probably be had for a dollar or two apiece.
edit1: oops, the 7912 might have a lower current rating, which does change what I just wrote.
Rats, I hate when that happens.
edit2: no, the MC7912 is spec'd for 1A like its 7812 complement. I was looking at an old LM7912 datasheet. I hate when that happens, too.
Old 6th May 2013, 10:05 PM   #9
I think I agree with you sofaspud, I'm going to use just one pass transistor on the 7812 and connect the 7805 after it like the first schematic for my current project.
Thanks again.
2-Way Sanity Check wrenchone Multi-Way 8 9th December 2011 07:54 PM
Capacitor Sanity Check treagle Tubes / Valves 6 19th March 2011 10:06 PM
Sanity check on B+ regulator 00940 Tubes / Valves 4 10th October 2010 04:04 PM
Sanity Check ..... please Lostcause Digital Source 0 16th October 2008 06:19 PM
Sanity check planet10 Multi-Way 14 7th March 2004 10:15 PM
Copyright 1999-2017 diyAudio
