Uni SMPS
Uni SMPS
Old 27th April 2013, 12:03 PM   #1
Acca is offline Acca  Serbia
Acca's Avatar
Uni SMPS
Lightbulb Uni SMPS
There's my universal smps from parts from pc power supply.If it don't start to oscillate,reverse feedback windings (15k resistor).I'll test it on some amps,and it works great.PCB is without rectifier,I'll finish it later.
Old 29th April 2013, 08:43 AM   #2
payloadde is offline payloadde  Europe
payloadde's Avatar
Question: EE33 transformer is from pc power supply too ? don't they have more like 3.3 / 5 / 12 V output rather than 28/0/28 ?
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 29th April 2013, 01:55 PM   #3
Acca's Avatar
Uni SMPS
Yes,not rewounded,this transformer give +-28V and +-11V , because duty is ~2x50%
Old 29th April 2013, 01:59 PM   #4
Acca's Avatar
Uni SMPS
Full bridge,1kW:
Old 1st May 2013, 01:40 AM   #5
Riff is offline Riff  Indonesia
Riff's Avatar
Originally Posted by Acca View Post
Full bridge,1kW:
its real can produce 1kw?
what driver you are suggest?
sorry my english.
Old 1st May 2013, 06:30 AM   #6
Acca's Avatar
Uni SMPS
Yes it can produce 1kW,driver EE-EI16/19
Old 1st May 2013, 06:32 AM   #7
Acca's Avatar
Uni SMPS
It doesn't produce 1kW on single ee33 but with two of these,it can.
And sorry for bad english
Old 1st May 2013, 07:23 AM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
Resistors or reverse connected diodes seem to be missing between B and E of the transistors (unless they are integral to the components used).
Without them, the charge on the coupling caps cannot be reset, and the converter will only be able to provide a small output.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophoneİ ♫♪
Old 1st May 2013, 04:55 PM   #9
Acca's Avatar
Uni SMPS
This is not right,i tested it,with diodes it doesn't working properly,(smaller frequency and dead time,transistors blow up)
Old 2nd May 2013, 12:55 PM   #10
Elvee's Avatar
Then the charge balance is ensured through some parasitic mechanism, probably B-E breakdown. The 330K's are much too large to provide the average base current.
Uni SMPSHide this!Advertise here!
Uni-T UT61E DMM PedroDaGr8 Equipment & Tools 2 13th June 2014 03:05 PM
Uni Project build sampleton Multi-Way 2 11th February 2013 10:51 PM
UNI-T UT600 Capacitance meter? Mayday Equipment & Tools 4 26th January 2012 07:29 AM
Uni project help Piper Solid State 6 18th June 2004 12:10 PM
