MDA fuse for a glass fuse. - Page 3 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 23rd April 2013, 10:07 PM   #21
srinath is offline srinath  United States
The BR3 looks fine to tests, 1 way resistance around 400 ohm for each pin pair, open other way.
I think the inrush is what is killing the fuses.
I got a working pre amp in this thing without these 2 fuses or a working power amp set. In fact I can remove the power amp boards and it still works as a pre.
Cool.
Srinath.
Old 23rd April 2013, 11:32 PM   #22
stormsonic's Avatar
Originally Posted by AndrewT View Post
I know which I would rather have in the mains supply to the transformer.
Yes it means I have to fit a soft start, but that is a small price to pay for a factor of 20 faster fuse blow.
IMHO fuses are not there to protect your equipment from fault, fuses are there to protect your house wiring from faulty equipment.
If transistor is protected with a fuse, transistor will always blow first
Old 24th April 2013, 09:14 AM   #23
AndrewT is online now AndrewT  Scotland
Fuses are there to protect all downstream components including the wiring from setting fire to the house.
I will still close rate my fuses and I will continue to argue that a close rated fuse is safer than a "conventional" fuse because it does not tolerate overloads as well. That "safer" includes the FACT that the close rated fuse blows far more quickly than a much larger fuse value.
regards Andrew T.
Sent from my desktop computer using a keyboard
Old 24th April 2013, 03:37 PM   #24
stormsonic's Avatar
Agree.
Old 24th April 2013, 11:48 PM   #25
Ok so my house is not on fire (BTW my carver mono's blew the breaker in the room ... but in its defense it was already a weak breaker) ... and the fuse still blows. I would try the slow blow ... waiting on order.
Cool.
Srinath.
Old 7th May 2013, 02:01 AM   #26
I got new slow blow fuses in ... and without speakers connected it does not blow them fuses.
When speakers are connected - It blows them in a few seconds.
I also feel the heat sink get very hot. I think I have a output or 2 that is shorting to ground.
Thanks.
Srinath.
Old 7th May 2013, 02:45 AM   #27
And in a hope that someone may give me the "a-ha" answer ...
This amp blew its fuses and whatever else when it was run at high volume on maggies.
And its display is very very very dim.
Cool.
Srinath.
Old 7th May 2013, 12:16 PM   #28
Are you glad you had fuses fitted?
regards Andrew T.
TO FUSE OR NOT TO FUSE? alibear Solid State 5 4th July 2012 02:14 AM
Fuse housing melting but fuse not blowing, ppi amp rawadia Car Audio 21 2nd August 2008 10:39 AM
Why main fuse and not rail fuse? digital desire Solid State 10 3rd December 2006 08:07 PM
amp rating for fuse and fuse holder? riotubes Parts 5 27th August 2006 03:10 AM
Copyright 1999-2017 diyAudio
