"Special" power supply
Old 23rd April 2013, 05:06 AM   #11
KVP is offline KVP  Belgium
I wouldn't worry too much anyway about your English, it's more than OK ;-)
Old 23rd April 2013, 01:02 PM   #12
FQR is offline FQR  Germany
Hello, KVP!
Thanks very much, glad to read this! My sorrow about that decreases gradually. And it seeems to be easier bit by bit, with every post.
One more mistake: In the thread, I mentioned (where Quasi warned of higher rail voltage) there was another schematic than Actrk 600, it was named "Atrk-nmos". There P-channel mosfets rated at 200V were used.
This two diagrams I have mixed up - sorry! I also donīt know which of the two would be easier to convert. On the Actrk diagram there are MJE350 used as drivers, theyīre rated higher (-300V), but I donīt know if higher voltage is possible therefore, cause the small signal BJTs are rated rather low, and at the schematic itīs marked again, that maximum is 90 Volts.
Please, couldnīt anyone give me tips for usage of other transistors, or values and position for adding resistors, to make say maximum of 115 V possible?
Greets,
Fred
"Special" power supplyHide this!Advertise here!
power supply schematic with a 6080 used as a "pass tube" jarthel Tubes / Valves 4 9th July 2012 02:25 AM
High Voltage Power Supply PCB "oopsie" Sale Geek Swap Meet 1 2nd January 2009 05:06 AM
Developing a "universal" tube power supply PCB Geek Tubes / Valves 42 15th August 2007 07:10 AM
"Power Tracking" in supply, ever heard, DIY ideas? Cradle22 Solid State 19 4th June 2003 09:02 AM
Audio Crafters Guild "Super Symmetric Power Supply" raincheck Digital Source 16 22nd April 2002 08:06 AM
