Go Back   Home > Forums > Amplifiers > Power Supplies
Old 16th April 2013, 12:02 AM   #1
Default RN-20 Chinese transformer connecting to JHL Amp board
Hello,
I have just purchased a pre-built JHL amp board and a transformer to go with it, and I am looking for a bit of a sanity check whilst I wait for it to arrive to plan how I am going to connect things.
This is the transformer: 30W 220V R Core Transformer 9V 2 15V 2 Free Shipping | eBay
The mains side is straight forward, One to neutral, one to active, (both are red so it doesn't appear to matter which one), and grn/yel to Protective earth. So far so good.
My question really revolves around the output side. I need a 15-0-15 ac supply. My first instinct is that I take each of the yellows as a +15 and the red attached to neutral as "0". Is this correct, or do I need to take one green and one yellow as my +15's?
Is there any benefit to me putting an appropriately sized capacitor bank between the output of the transformer, and the input to the amp? Space in the enclosure isn't a problem, but if there is likely to be no benefit I wont bother!
If you could please let me know if my interpretation of the transformer is correct it would be really appreciated!
Old 16th April 2013, 01:23 AM   #2
OK. Looking at pictures of these installed in finished kits, my assumptions with the outputs are clearly wrong.
Can anyone point me to a document / website / whitepaper so that I can learn how this should be wired?
Old 16th April 2013, 02:23 AM   #3
ok.
Lets see if I got this right now....
To get the output I need, I would connect one yellow as +15, one green as +15, and the remaining yellow and green would connect together to get my 0.
Is this correct?
Old 16th April 2013, 10:29 AM   #4
DF96 is offline DF96  England
Yes.
Keep the reds (mains primary) well away from the secondaries. The green/yellow striped wire (screen) should attach to the grounded chassis. You should also make a connection between chassis and the circuit 0V point, but possibly not your green+yellow junction - read threads on grounding to avoid hum.
In stock pcb for JHL 1969/PASS F5/NAP140/6N3 PRE-AMP/JHL headphone diyhifishop Vendor's Bazaar 6 29th August 2012 07:48 AM
Parts Express DOTD 20-0-20 200W transformer $5 officeboy Parts 20 21st June 2010 09:02 PM
Where in Brisbane can I get a transformer for my Chinese amp data Tubes / Valves 7 17th February 2008 08:50 AM
Tripath TA2020-20 6 Channel Amp Board john65b Class D 1 21st September 2005 04:43 AM
Jhl Class A Amp Pcb colin.hepburn2 Solid State 0 19th January 2003 12:34 AM
Copyright ©1999-2013 diyAudio
