18V + 18V Power Adapter = +/- 18V Power Supply ?
Old 9th April 2013, 12:35 AM   #1
staticGeneraor is offline staticGeneraor  United States
Default 18V + 18V Power Adapter = +/- 18V Power Supply ?
I have two 18V power adapters (computer - same brand) and want to wire them for use. If I wire them this way, will there be any concern with the power supplies melting or ruining the circuits?
Old 9th April 2013, 11:33 AM   #2
R.I.P.
Try it and measure to ensure you get what you expect.
Make sure the mains fuse to both supplies is about the right size.
The problem occurs where the "ground" of the supply is connected to the Chassis enclosing the SMPS. That Chassis MUST be connected to PE. In this situation you CANNOT series connect the PSUs.
This applies to the SMPS that power desk top computers.
But where the PSU is double insulated to ClassII standards and has no PE to connect to, then you CAN series connect the PSUs. As many as you like, eg. four 19Vdc laptop supplies to give +-38Vdc to power an amplifier.
regards Andrew T.
Old 13th April 2013, 10:22 PM   #3
Hi Andrew,
Thanks for getting back to me. I think I follow you.
These are laptop power supplies (in plastic cases) so I think the double insulated should apply, but I'll check. If the AC wall plug has only two connectors, I should be OK? So I'm powering op-amp style projects so need the center power for that.
18V + 18V Power Adapter = +/- 18V Power Supply ?Hide this!Advertise here!
2 Toroidal Transformers 110V-18V/18V Gundholt Swap Meet 2 23rd January 2011 02:58 PM
FS: (2) 18v+18v 400VA Antek Toroid Transformers mezz64 Swap Meet 3 5th May 2010 05:10 PM
Plitron 300VA 230V/18V-0-18V for Firstwatt khundude Swap Meet 2 8th September 2009 07:06 PM
help with 18v 4A power supply AudioGeek Power Supplies 1 9th April 2006 08:00 AM
WTB: 18v-0-18v 40va transformer cowanrg Parts 2 3rd October 2003 03:41 AM
