Simple DIY Rectifier?
Old 26th March 2013, 05:58 PM   #21
cogitech is offline cogitech  Canada
cogitech's Avatar
Originally Posted by FoMoCo View Post
Without seeing the schematic, I can't say. I'd assume that it'll trash both the amp and the pre-amp to be safe.
Well, that wouldn't be any fun.
I don't have access to the schematics. Perhaps better to leave it alone and find something else to tinker with.
I do need to complete the chassis and optimize wiring, after all...
Old 26th March 2013, 06:00 PM   #22
sofaspud is offline sofaspud  United States
sofaspud's Avatar
That's my thought also. Any enclosure big enough to hold the big cap and preamp & amp boards will have enough room for the dual supplies. It already looks pretty good, just need to move the cap to the other side.
It is error only, and not truth, that shrinks from enquiry. - Thomas Paine
Old 26th March 2013, 06:00 PM   #23
alexmoose is offline alexmoose  United States
alexmoose's Avatar
It just seems to me like it would be more money/trouble than its worth. But I ain't your pa.
I have a more grown-up version of this basic idea. I use a computer power supply to run the tripath amp, I know everyone's going to freak out at that, but they are dirt cheap and have more current than you can shake a stick at.
Old 26th March 2013, 06:05 PM   #24
cogitech's Avatar
As I said, I have all sorts of components and the objective would be to do it for free. The "trouble" is what I enjoy about this stuff. That's the beauty of doing this as a hobbiest/hacker. It is not time wasted or lost.
Whatever works!
Old 26th March 2013, 06:08 PM   #25
cogitech's Avatar
The big cap will be mounted on top of the chassis (not inside) with that bracket holding it in place like on some old tube amps. The larger transformer will be mounted on top also, and there will be a hole cut out of the top plate to let the tube poke through.
Old 26th March 2013, 06:23 PM   #26
JMFahey is offline JMFahey  Argentina
JMFahey's Avatar
1) connect transformer to 6A bridge to big filter cap.
Then bridge to filter cap legs.
*Then*, using separate red and black cables, as thick as possible (1mm to 1.8 mm , "translate" to AWG if you wish) feed whatever needs to be fed 12V.
It's bad practice bringing DC "down" and sending charging pulses "up" through the same wires.
2) load that filter cap with a 4 ohms 10 to 20W resistor or with (maybe easier to find) 1 or 2 car lamps , about 24 to 32W total, to see what yout PSU *actually* delivers under load.
If it drops to around 13V (quite possible) I think you can feed your Tripath with it.
Please google and post TA2020 datsheet to check.
Old 26th March 2013, 06:27 PM   #27
cogitech's Avatar
I'll have to go over this a few times before I understand exactly what to do, but thanks for the reply. And yes, the TA2020 can take up to 14.6v (actually, absolute maximum is 16v, but safe limit is 14.6).
Old 26th March 2013, 06:31 PM   #28
FoMoCo is offline FoMoCo  United States
Just one problem. Music isn't a sine-wave. He will be drawing less current than max most of the time. If the line voltage is just a bit high and the amplifier not overdriven, the 16V max on the datasheet will be exceeded.
Account Deletion Requested: 1/26/2014
Old 26th March 2013, 06:35 PM   #29
cogitech's Avatar
Good point. I'll be typically drawing much less than max. In fact, the amp is already getting a bit over 13 volts from the existing DC supply because it isn't loading it enough. Still safe, but not safe if that was 16v.
Old 26th March 2013, 09:17 PM   #30
JMFahey's Avatar
Fine enough.
Didn't know Voltage spec was *that* tight, that's why I asked.
*MY* favorite "car amp" chip is TDA2005, I have sold hundreds of 12V 7A battery powered Guitar/Mic amplifiers powered by them.
And although meant for a 12.6V battery, they work up to 18V, can stand 28V and short peaks of 40V, go figure.
Looks like often "old tech" is better
http://www.ozitronics.com/data/tda2005.pdf
Here's one of my biamplified TDA2005 + TDA2003 "FAHEY Callejero" amplifiers:
Simple DIY Rectifier?Hide this!Advertise here!
Simple P-P Rectifier Einric Tubelab 4 2nd July 2012 01:36 AM
Simple rectifier/filter board discrete Power Supplies 0 4th November 2010 01:28 AM
Simple SE and Rectifier Manipulation bigjppop Tubelab 1 16th January 2010 11:11 AM
simple transformer/rectifier problem... maxw Power Supplies 7 10th August 2005 10:55 PM
Simple bridge rectifier question. JoeBob Everything Else 51 15th February 2002 07:46 PM
