Need opinion
Need opinion
Old 22nd March 2013, 07:58 PM   #1
tony Ma is offline tony Ma  United States
Default Need opinion
Hi All,
Here is PCB that I will use for Aleph 30
My questions are
1. PCB trace is about 5 mm is that ok?
2. Input and out voltage is close, is that ok? ussually I seen Input voltage on one side and the out put is on the other side
let me know please....
Old 22nd March 2013, 08:01 PM   #2
DF96 is offline DF96  England
Are the labels correct? You seem to have D- connected to V+.
Old 22nd March 2013, 08:05 PM   #3
Yeah you are right.... supposedly the other way around
Old 22nd March 2013, 08:09 PM   #4
Corrected
Old 22nd March 2013, 09:29 PM   #5
godfrey is offline godfrey  South Africa
Originally Posted by tony Ma View Post
Corrected
Why not use more copper? e.g. Thicken the V+ and D+ tracks and fill in the whole center area between GND and D-. It doesn't cost any extra. In fact if you're etching you're own boards, it saves money.
P.S. Are those resistors supposed to be 0.47 Ohms? Seems too low for effective filtering.
Old 22nd March 2013, 09:44 PM   #6
You just have to be careful that ground currents from charging pulses don't end up in the wrong place. Leaving the ground trace as a line rather than an area maintains the clear distinction between PSU input from rectifier (dirty) and PSU output (clean). Then the clean end can go to the signal ground without injecting buzz.
Old 23rd March 2013, 12:00 AM   #7
I got what you are saying
Maybe this one is better?
Old 23rd March 2013, 12:02 AM   #8
What value you are suggesting for the resistor?
Old 23rd March 2013, 01:21 AM   #9
Yes, but it still needs more copper. You're etching away all the good stuff.
No suggestion, I was just surprised at the value. If that's what Nelson suggests, I certainly won't argue.
Old 23rd March 2013, 01:35 AM   #10
[QUOTE=godfrey;3423310]Yes, but it still needs more copper. You're etching away all the good stuff.
What about this??
Need opinionHide this!Advertise here!
I need your opinion please bega_83 Car Audio 9 10th March 2010 11:17 AM
looking for opinion xxxwhezzy Car Audio 9 8th May 2008 03:53 PM
Your opinion, please croccodillo Tubes / Valves 2 14th September 2005 03:40 PM
opinion oldbar Multi-Way 11 25th May 2005 05:25 AM
Want your opinion! vdi_nenna Pass Labs 9 16th January 2004 03:27 PM
