50V to +/-15 - Best solution?
Old 3rd March 2013, 07:04 AM   #1
gruni is offline gruni  Germany
Default 50V to +/-15 - Best solution?
Hi everybody!
I'm repairing an old Lab Power Supply right now. It used to have some weird current sourcing/sinking used in the power supply. I already completely "modernized" the control circuit using JFET current sources etc. so my design only needs +/-15V supply. But i want to keep the original transformer that puts out a single 50V supply. So my question is: what is the best solution to convert 50V to +/-15V? I already thought of two zeners and a resistor, two cascaded 7815 (altough there would be a problem of too high input voltage) or regulation to 30V and using a rail splitter… What do you think is the best? Or is there something better?
Thanks in advance!
Old 3rd March 2013, 07:25 AM   #2
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
How much current is needed for that +/-15V? Does the transformer has an 50Vac output or those 50V are after rectifyer and filter cap?
Have a go at my latest set => Dj Marik -
Trance session live ep. 94
Old 3rd March 2013, 08:32 AM   #3
50V after filter cap. The +/-15V rails have to supply power to four opamps (TL074) so i think no more than 100mA are needed.
Old 3rd March 2013, 08:36 AM   #4
MarianB's Avatar
Ok then, you can go either with a floating ground or with voltage doubler, witch one seams more to your liking?
Old 3rd March 2013, 09:09 AM   #5
payloadde is offline payloadde  Europe
payloadde's Avatar
similar discussions here:
http://www.diyaudio.com/forums/power...nto-15v-2.html
and here:
+/-15vdc 7815, 7915 Power supply
doubler is technically O.K. and probably best, but since you already have a high voltage it doesn't seem reasonable to go to 100v first ...
QUAD used a capacitive splitter w/o doubler in their 606 amp to obtain +/-V and virtual gnd from single DC
— Why not buy Keith Snook a BEER —
note T15 / T16 device to keep balance
Judge: This court appreciates that you invented physics, Mr.Newton, but unfortunately you can't have a patent on it.
Old 3rd March 2013, 09:14 AM   #6
I read those threads but thats not exactly what i'm searching for. The problem that bugs me most is the quite high voltage from the transformer. If i had a 15 to 20V winding, i would just use the voltage doubler design seen everywhere. But 50V is too high for feeding 78XX regulators. So i dont think a voltage doubler would make sense in this case. I think the most desireable solution is to use two 15V zeners and a resistor? What do you think?
Old 3rd March 2013, 10:17 AM   #7
MarianB's Avatar
How do you intend to split a supply with 2 zenners?
Old 3rd March 2013, 10:19 AM   #8
Elvee is offline Elvee  Belgium
Elvee's Avatar
A dual-output capacitive supply with 15V zeners seems like the most reasonable solution.
That won't waste too much power.
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 3rd March 2013, 10:37 AM   #9
MarianB's Avatar
I am not a verry big fan of the virtual ground ideea, it might create problems when connected to other fix grounded circuits... i think voltage doubler would be better, 50Vdc means about 35Vac from the power transformer, and with voltage doubler about +/-50Vdc, a zenner diode each rail helped by a BJT would do just nicely.
Old 3rd March 2013, 11:14 AM   #10
palstanturhin is offline palstanturhin  Finland
palstanturhin's Avatar
Why?
He has a transformer in there...
Its still floating isnt it?
50V to +/-15 - Best solution?Hide this!Advertise here!
Power Supply -50V gnd +50V RipX Power Supplies 31 24th June 2013 02:52 PM
Antek AN-5450 500VA 50v-0-50v, 18v , 12v Therum Swap Meet 3 19th July 2011 01:07 PM
WTB: BGN 4,7uf 50v, 10uf 50v & 22uf 16v Pocoyo Swap Meet 1 16th September 2010 02:09 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 04:19 PM
Copyright ©1999-2017 diyAudio
