50V to +/-15 - Best solution? - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 3rd March 2013, 12:51 PM   #11
MarianB is offline MarianB  Romania
MarianB's Avatar
Send a message via Yahoo to MarianB
Virtual/floating ground creates problems on interconection between stages, you have to be sure it is ok to use it, you have to make sure it will not affect or be affected by other circuits connected to it...
This is my sugested solution
Have a go at my latest set => Trance Session Live ep 67
Old 3rd March 2013, 01:20 PM   #12
Elvee is offline Elvee  Belgium
Elvee's Avatar
A basic example of capacitive, non floating supply:
. .Circlophone your life !!!! . .
♫♪ My little cheap Circlophone© ♫♪
Old 3rd March 2013, 01:31 PM   #13
MarianB's Avatar
That is just a voltage doubler, and what i have sugested...
PS: What use do you have for R1 and C1?
Old 3rd March 2013, 01:58 PM   #14
FoMoCo is offline FoMoCo  United States
One easy solution would be a simple DC-DC converter designed for telecom use. They're 48 Vdc in and you can choose the desired output voltages. They usually will tolerate 36-72 volts on the input.
Account Deletion Requested: 1/26/2014
Old 3rd March 2013, 03:23 PM   #15
Elvee's Avatar
It would become a voltage doubler if it happened to be operated open circuit, which is normally never the case.
R1 limits current spikes, at power on for instance, and C1 sets the average output current. Each cycle, it transfers a charge of C1*2*Vpeak to one of the outputs, leading to an average current of Q*Fmains, 50Hz in this case.
Power Supply -50V gnd +50V RipX Power Supplies 31 24th June 2013 03:52 PM
Antek AN-5450 500VA 50v-0-50v, 18v , 12v Therum Swap Meet 3 19th July 2011 02:07 PM
WTB: BGN 4,7uf 50v, 10uf 50v & 22uf 16v Pocoyo Swap Meet 1 16th September 2010 03:09 AM
Looking for a ~40-300Hz Horn solution with a 15" Driver Bass-Depth Multi-Way 20 1st April 2006 05:19 PM
Copyright ©1999-2017 diyAudio
