Suggestions on regulating -70v
Old 28th February 2013, 04:53 AM   #1
impsick is offline impsick  United States
impsick's Avatar
Default Suggestions on regulating -70v
Trying to make a power supply for a mic that requires +70v -70v. I found the TL783 for regulating +70v but haven't found anything to regulate the -70v.
Any suggestions, tricks, schematics, tips would be awesome. thanks
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 28th February 2013, 06:05 AM   #2
picowallspeaker is offline picowallspeaker  Italy
picowallspeaker's Avatar
For such low currents that may happen in mic & preamps, a zener diode
is sufficient, for both the rails. You might want the zeners and the resistors
to be 1/2 W. Add two more decoupling capacitors and you've got a six components voltage regulator for + and - 70 V.
Old 28th February 2013, 02:53 PM   #3
Mark Johnson is offline Mark Johnson  United States
My suppliers don't stock 70 volt zener diodes but they do stock the NZX36, 1N5258, and 1N4753, all of which are 36 volt zeners. So you could build zener regulated, capacitance multipled supplies using MJE340 / MJE350 as series pass regulators. 6 components per rail.
Old 28th February 2013, 09:25 PM   #4
impsick's Avatar
awesome, thanks for the input guys!
Old 28th February 2013, 10:09 PM   #5
Robert Kesh is offline Robert Kesh  Wallis & Futuna
Robert Kesh's Avatar
if you have two secondaries, you can use a positive chip regulator "upside down" as it were, to regulate the voltage between the ground and the negative. you must form the ground point after both regs, not before
also, you can use a lower voltage regulator and attach zeners to the adjust to take it up, so long as the drop between Vin and Vout doesn't exceed spec, and you don't short the output by accident
Old 1st March 2013, 02:55 AM   #6
impsick's Avatar
do you have an example schematic for your first suggestion?
Old 1st March 2013, 03:15 AM   #7
dangus is offline dangus  Canada
If you're using a 3-terminal regulator, just using a sufficiently large resistor on the Adj pin could work. Take a look at the application notes; there's a wealth of information there on power supply design.
Alternatively, this might be a case where shunt regulation makes sense. I have a hunch that could be electrically quieter than using a zener. I assume that a microphone needs very quiet supply rails.
Old 1st March 2013, 10:27 AM   #8
protection diodes, caps, resistor values, should all be as datasheet
Old 1st March 2013, 10:29 AM   #9
I have always wonderd about the PSRR of a mic, and can never find any info. Luckily the standard 48V phantom power is easily regulated with a LM317HV
Old 3rd March 2013, 10:39 PM   #10
impsick's Avatar
Thanks for that schematic Robert. That totally helps.
this might be a stupid question but say I also wanted 5v. Can i add another LM7805 to one of the windings or would I need another winding to do that with this set up? Thanks
Suggestions on regulating -70vHide this!Advertise here!
Ryan regulators not regulating? bobschneider Solid State 0 15th August 2007 11:14 PM
Self regulating Class A Kees Solid State 50 14th October 2004 09:41 PM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 10:42 PM
7815 not regulating. JoeBob Solid State 16 8th September 2003 01:51 PM
