Suggestions on regulating -70v - Page 2 - diyAudio
Go Back   Home > Forums > Amplifiers > Power Supplies
Old 5th March 2013, 03:03 PM   #11
MelB is offline MelB  Canada
You will be dissipating a LOT of energy to get 5v out of that. I would use a winding that is closer to your intended output voltage.
Old 5th March 2013, 05:10 PM   #12
impsick is offline impsick  United States
impsick's Avatar
well my plan was to use a voltage quadrupler to get the 70v.
"Nothing happens for a reason. There are just reasons why things happen." Quote me on that. http://stores.ebay.com/AudioGrade?_rdc=1
Old 5th March 2013, 05:37 PM   #13
impsick's Avatar
Here this is what I had in mind... Would this work or am I in need of exclusive windings? thanks.
Old 6th March 2013, 07:53 AM   #14
impsick's Avatar
well I tested the schematic above, it works, but now the 70v rails are uneven.
any suggestions on how to compensate? Could this just be a case of tweaking resister values? Or any design techniques anyone can share? thanks in advance.
Old 6th March 2013, 03:02 PM   #15
Robert Kesh's Avatar
Yes. the reg's ref voltage is usually listed as 1.2 to 1.3V. So potentially up to 8% difference between any 2 units. So tweak resistors to compensate.
Old 6th March 2013, 04:01 PM   #16
jackinnj's Avatar
You can use the "2 Transistor Regulator" from Jones "Valve Amplifiers" -- the output voltage will be ~2x the value of the reference. It's good to around 40-50mA and very simple to implement.
For more current use a Darlington transistor as the pass element.
Old 6th March 2013, 08:55 PM   #17
impsick's Avatar
Thank you all
Ryan regulators not regulating? bobschneider Solid State 0 15th August 2007 11:14 PM
Self regulating Class A Kees Solid State 50 14th October 2004 09:41 PM
LM3x7 HV regulating. w00t Parts 3 29th February 2004 10:42 PM
7815 not regulating. JoeBob Solid State 16 8th September 2003 01:51 PM
Copyright 1999-2017 diyAudio
